Deciding between 19x9 front & 19x10 or 19x11 rear & tires... help!
What looks like a better 'match' to you, I'm stuck between these two setups:
RIM 19x9 235/35/19 - tire height 25.5", tire tread width 8.3"
RIM 19x10 255/35/19 - tire height 26.0”, tire tread with 8.8”
or
RIM 19x11 285/30/19 - tire height 25.8", tire tread width 10.2"
Here are the tire options I have with the tire I chose (Bridgestone RE050A Pole Position)
265/30R19
275/30R19
275/35R19
285/30R19
or
265/30R19
275/30R19
275/35R19
285/30R19
What looks like a better match to you? Looking for over all similar streatched look for front & rear:
front: RIM 19x9 235/35/19 - tire height 25.5", tire tread width 8.3"
rear: RIM 19x10 255/35/19 - tire height 26.0”, tire tread with 8.8”
or
rear: RIM 19x11 285/30/19 - tire height 25.8", tire tread width 10.2"
or
U could do 265-30 of u want a stretched look I have 265-30 on my car and its 10.5 wide in da rear and its def a stretched look. 285 is not going to give you a stretched look at all
im thinkin 285 for the rear 11 might be too fat. #1 because our IS dont really fit an 11 (with unknown offsets) so you need to do some kind of fender cut and some pull. Check out the G35 and 350z forums. Ive seen em put 255, 265, 275 on 11 rears so that it wont rub as much. Trust me I have an 11 rear and am running 275
Thanks all for the reply's, keep em' comming. Here's my thoughts so far, which are very open to critque.
pros: the rear tire/rim is with-in the mfr specs (they say 10.0" rim is widest and is within mfr specs)
cons: rear tires are only 1/2" wider then fronts, but 1.0 full inch wider rim width (seems the rear will have a more stretched look)
or
pros: rear tire/wheel & front tire/wheel look to be more equal (both seem to be almost exactly 2 inches apart, which SEEEEEEMS like they will 'look' similar)
cons: rear rim/tire is out of mfr specs. bridgestone says widest their 285/30/19 should go on is a 10.5
or
