Wiper Blade fluid not coming out
Good day to you all, having a little issue. My fluid for my wiper blades is not coming out. I went out and bought rain-x, however I just want to make sure my car isnt going on the fritz!
I went out and filled up the wiper blade reservoir, and still nothing![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
any suggestions or ideas? i'm at a loss. It's been below freezing, but that's all I can think causing any issues
Super Moderator
do you wax your car often? you could have clogged up the shooters. make sure the hole is completely clean. i remember a thread a while ago with another member having trouble with their washer fluid and after throughly cleaning out the hole where the fluid comes from, everything was fine
I had an 85 MR2 (aka mid engine), but the wiper fluid tank was under the front 'hood'. Since there was no engine heat there, the sucker froze up solid and didn't thaw until the weather improved.
I am thinking the dealership put in some cheap stuff, it got above freezing, and I finally was able to wash my car, and I put in new fluid, and the first time I went to use it it shot out, like it was clogged (or frozen) ![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Yes, I picked up some fluid like that who claims it will work all the way down to that level...I'm real close to pullin a Lane Kiffin and move back to Cali..this weather is TERRIBLE
um not in my is350 but i remember my dad poking the 3 holes from each side with a needle precisely and that did the trick. i have a feeling it might be the same? that happened to my old audi a6 back in the days.
like on the left side, only 1 of the 3 holes would shoot water. After examining and poking it that did the trick![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
just trying to help you out
but again examine thoroughly first
