19x10.5 +22 All Around? Easy / Hard ?
not trying to thread jack but i'm looking into some rims too, you guys say 19x10.5 +22 is do-able in the rear w/ some shaving but how about 19x9.5 +22 front? i'm pretty sure its to aggressive, it would need to be +30's to 40 but just want to verify from someone who knows the offsets on our cars.
as for the rear with a 22 offset on a 10.5...can work but remember u guys are gonna run about 3-5 degrees camber...if ur willing to buy new tires every 6 months lol, I have air so I'm good, I run a 18 offset on a 20x10.5 and run about 5-6 degree camber
I have 20x9.5 with 24 offset, should be ok; ur gonna need to get 30 series tires and camber bout 2-3 degrees
the camber doesn't kill tires. Toe does. zero out the toe and you will be fine.
so your saying 19x10.5 +22 all around will work?
I think im gonna take it down a notch.
im probally going to stock with 18s with about 9.5-10" wide all around with offsets in the low 30s to 20s.
so around 18x9.5 ~ 18x10 +30 ~ +22
