HELP... CHECK ENGINE, VSC, Slip Indicator..
I have an AWD IS250 with 17k miles on it. I put wheels on at 14k miles.. THey are staggered but with in the allowable tire range.
I was at a stop light today when my check engine light, the slip indicator light, as well as the display stating to "CHECK VSC" all came on...
PLEASE tell me its not my transmission?!?!?
Any ideas??
Any ideas??
what makes you think its the transmission lol It happened to me last week, i cant tell you what was it exactly, but the cause was that i got stuck in snow really bad; anyways i took the car in; they reset the computer(or whatever)&everything went back to normal. It took 10min.
Any ideas??
Any ideas??
time for a dealership visit. if you are running a staggered set-up but within an allowable range, it shouldn't be your transmission.
however, it MIGHT be your center differential.
then again, i'm just guessing.
Super Moderator
The "Check VSC" and slip icon come on any time you get a check engine light. That's because the car automatically disables VSC automatically when the check engine light is on. As for the check engine light, the first thing to check is whether the gas cap is loose. If that is not it, you'll need to bring it to the dealer, or someone else with a scan tool to read the codes.
Tech Info Resource
If it were mine, I'd take it to Autozone and have them read the codes, post them here, I'll look them up and we can figure out if it might be the wheels or if its something entirely unrelated (which is VERY possible). Once you know what the DTCs mean, THEN you can take it to the dealer (assuming it ISN'T the wheels) and have it fixed under warranty.
BTW, I personally wouldn't go to Autozone - I have an OBDII scanner in my tool box.
thanks for the advice guys!!!
2 days after I posted this, my check engine light turned off... but than came back on while I was driving to work. At this point I realized that it wasn't my transmission, so I took it to the dealer, (cuz they had to replace my fuel rail anyways).. turned out that my Air Fuel sensor was bad.. they replaced it for FREE!!!
seanmwple
08-23-23 05:44 PM
Mamba2481
12-24-18 04:15 PM
Orozco27
02-20-14 05:52 AM
kabear808
01-31-14 12:59 PM
