How to Change the Transmission Oil in my IS250?
#32
Yes, you must drop pan (twenty 10mm bolts) to get to & replace filter (four more 10mm bolts to take off filter).
It is a black plastic box piece with the spongy filter inside.
And yes, it is recommended to also replace the pan gasket too, using a thin layer of grey or black Permatex rigid high-torque RTV Silicone gasket maker.
Furthermore, there is also a separate O-Ring for the filter piece, which you should probably also replace.
These three parts can be found on LexusPartsNow.com (I ordered them just now, as a matter of fact!)
The following are for my car, which is a 2006 Lexus IS250 RWD (GSE20), with nearly 200k miles (God help me!).
You can find out your transmission type from Wikipedia's IS 2nd Gen page: https://en.wikipedia.org/wiki/Lexus_IS_(XE20)
Here are the parts I just ordered for filter change on MY car, again a 2006 Lexus IS250 RWD (GSE20), from LexusPartsNow.com:
Part No. Description Price Qty Subtotal
35330-30090 STRAINER ASSY, OIL [*FILTER*] 48.05 1 48.05
35168-22020 GASKET, TRANSMISSION 21.64 1 21.64
90301-31014 RING, O 2.65 1 2.65
Subtotal $72.34
Tax $0.00
Shipping & Handling $15.36
Total $87.70
Subtotal $72.34
Tax $0.00
Total $87.70
Also, here is a good post/thread on HOW-TO replace trans filter on a similar gen Lexus GS (part#s are the only difference):
Changing Transmission Filter/Strainer ***DIY w Pics*** for GS - 3rd Gen (2006-2011):
https://www.clublexus.com/forums/gs-...iy-w-pics.html
Good luck!
#34
Just a quick FYI: If you don't see any of the pics in that DIY post on filter change, try another browser or computer.
Not sure why, but they aren't loading on my computer (probably because it's an XP box with outdated Chrome, lol).
BUT, however, the images DO load in the webpage on my Win7 laptop...
#35
Personally, I hate dealing with RTV, out of concern that the excess squeezes inside the pan and plugs something -- at the very least a good chunk of RTV may lodge against the filter material and reduce it effectiveness. I would much prefer a gasket that is laid on a cleaned surface, like LubeLocker.
