Anyone from the northern states with rear view camera?
Hello!
Are there any owners of IS (with rear view camera) from the northern states?
Could you please check the following:
1) The outside temperature is 10F and lower
2) Its got dark outside
3) You haven't used "reverse" for 10 minutes and more
When you select "reverse" and see the picture from the rear view camera, do you notice almost transparent vertical lines on the image which disappears after 3-5 seconds?
My dealer says that this is normal behavior but I'am not quite sure about that.
Thank you in advance for your help!
