Tire, width, sidewall and overall diameter question
Right now im running (in the rear) a 275/30/19 (rims are 9.5)
Theoretically
my sidewall hieght would be 275mm X 0.30 = 82.5mm
now if i switch to a not so wide tire, 255/35/19
sidewall height wll be 255mm X .35 = 89.25mm
so the total diameter of the wheel is bigger on the 255 tire by 13.5mm.
BUT
then how come it looks like the tire is thinner on a 255 than a 275 in real life? Is it because of the stretch (255 will be more stretched than the 275 on a 9.5??) and therefore will give the illusion than the tire is thinner?
Ive seen pics of a 255 tire on my rims and it looks alot thinner than my 275 tire (exact same rims and tire brand, just diff sizes.)
Theoretically
BUT
Also is there any advantages/disadvantages in durability and comfort from running a 275mm tire than a 255? or vice versa? which is better
I know the wider the tire the better the ground contact and therefore the grip, but with these sizes isnt marginal?
I got Michelin PS2, and the sidewall is quite thick, which is kinda ugly haha
Im considerign the swtich from:
245/35/19mm (8.5inch wide rim)
275/30/19mm (9.5 )
to
225/35/19mm
255/35/19mm
but from the all the tire calculators it seems like ill be makin my tires beefier (none of them ask for rim width though, so hence my OP)
275/30/19mm (9.5 )
to
225/35/19mm
255/35/19mm
That measurement is if the sidewall was straightened out. If you stretch it over a wider wheel, some of the larger sidewall height gets lost in the now stretched width. I'd stick with what you have
funny enough i got my current tire sizes recommendation from CL members
My rim manufacturer recommends the sizes im considering changin to. (255/35/19)
I also just received some spacers (will b at +30 offsets), so will rub on current setup
