Volk GT-7's
I have a would this fit question, I'm looking at a set of volks locally but they came off a G35 and I'm not sure if they'll fit, the offset seems pretty low...
This is what is for sale:
Front:
19”x9.5”
+30mm
Toyo Proxes T1-R 245/35/19 @ 85%
Rear:
19”x10.5”
+24mm
Toyo Proxes T1-R 275/35/19 @ 80%
Will these fit without any rubbing if I'm lowered about 1.5"?
Thanks for your input!
Front:
19”x9.5”
+30mm
Rear:
19”x10.5”
+24mm
this will not happen forever, even with major fender mods, you will still have hard time to fit the front set-up unless you wanna run 215 tires, but noway the rubbing will be completely gone, not in this planet
Come on guys, these will fit with a roll up front and a cut in the rear.
I ran a 9.5 + 34mm with a 235/35 and NEVER rubbed in the front while I was tucking tire.
I'm on a 10.5 +22mm in the rear now. I'm tucking tire rolling on a 265/30. And I only rub on huge dips at 70+ MPH. And its not a bad rub.
Thanks for all the feedback - I guess the consensus is that I'll have to do some major fender rolling/cutting to make it fit.... hmmm, not sure if I'm that committed to this cause
jucee187
Wheels, Tires & Brakes Forum
11-17-03 10:20 AM
