Check VSC/Engine light - Too much air?
Old 02-20-10, 09:48 AM
odon76
odon76's Avatar
Default check vsc light
I 'm having the same problem with my IS 350. Apparently my gas cap wasn't tight. After tightening it the light remains on and it has been 4 days now. However dont notice any changes in the way it drives. Although I just put in an Injen intake but now also considering putting my stocks back on. I seem to notice most people I have talked has the same problems right after the warranty of 50,000 miles. I currently have 55000 + miles. I thought Lexus was suppose to be about luxury and reliability, not so sure now. But my Lexus GX470 has never had any problems......knock on wood.
Old 02-20-10, 10:21 AM
06isDriver
06isDriver's Avatar
Autozone in most states (except California) can test and reset your codes usually for nothing. The important thing is it find out what the code is.
If you're getting a code repeatedly, you should find out what the code is. If its from not putting on the gas cap tightly, you should be told about it.
Autozone will NOT reset your codes. they consider it a major liability.
Old 02-20-10, 10:51 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,996 Likes on 2,420 Posts
Sounds like they don't reset in Louisiana either.
Seriously - they consider resetting the code a liability, but they'll sell you a scanner to let you reset the codes by yourself indefinitely? Somebody's lawyer isn't getting the whole story here.
Old 02-20-10, 05:13 PM
Wish
Wish's Avatar
its not b/c of intake for sure, this error comes into 2006/2007 models I use to have it in my previous IS.
Although I didn't have any mods by that time. fixed by the dealer.
Old 02-20-10, 05:17 PM
06isDriver
06isDriver's Avatar
Yeah I know...I thought it was very strange, but the autozone fella was VERY emphatic. I did have to buy a scanner to clear the lean codes I was getting.
Old 02-21-10, 08:47 AM
Caboose
Caboose's Avatar
I've been driving around with the warning light on for awhile, my intake filter is damaged and i think there is a puncture in it somehwere. I tried ordering another but they are on back order :/ so i guess il have to find another company with same specs
Justaman
Maintenance
06-17-19 08:41 AM
rogal
IS - 1st Gen (2001-2005)
12-15-14 02:07 PM
VinayRaju
Performance
07-03-14 01:21 PM
UCLAJimmy
08-24-10 06:20 PM
lilthanh19
03-27-08 07:10 PM
Quick Reply: Check VSC/Engine light - Too much air?
