Need HELP!!! ASAP (LED Tail Light Problem)
02-03-10, 11:35 AM
03-19-10, 08:10 PM
ah.. exact same problem..
03-22-10, 06:31 PM
the solution to this problem is to ask for a resistor from the seller. esp for the 2008
09-20-10, 04:34 PM
sorry to bring up a old thread but what resistor do i need and where does it go?
thanks
09-20-10, 05:31 PM
Quote:
Originally Posted by
redline201
thanks
It comes with the tail lights and they connect to the outer corner lights. My tail lights work perfect, no problems.
09-20-10, 05:54 PM
i picked mine up used. maybe i can contact an ebay vendor
09-20-10, 06:17 PM
redline201
Have you tried the person who sold it to you first?
09-20-10, 06:35 PM
sorry for miss reading the posts, what you are saying the problem after install the EBAY LED light? or upgrade 09+ one?
09-20-10, 07:00 PM
redline201
Are you sure you are missing it? Its just an extra wire that is already connected to the corner lights, it wasn't separated when I received mine.
09-20-10, 07:22 PM
I see some 6ohm 50 watt resistors on eBay. With that work?
10-24-10, 12:26 PM
do 07's require resistors with ebay led tails?
06-30-11, 05:08 AM
My car won't even start after swapping oem for oem. Imagine that one.
06-30-11, 05:17 AM
CCJ22
When you swapped did you swap the wiring harness? and is the other person having the same problem?
08-19-11, 07:41 PM
08-19-11, 09:43 PM
will the same problem happen to 2007 IS250?
Nespo2330
10-09-16 04:52 PM
Lveyolfe
04-29-14 11:40 AM
shademand
RX - 1st Gen (1999-2003)
04-09-10 12:43 PM
ARISTOh
03-11-10 10:30 AM
Saiji
Lighting
10-23-07 02:29 PM
asap ,
bulb ,
clublexus ,
earlier ,
forum ,
is350 ,
led ,
lexus ,
light ,
lights ,
model ,
problems ,
sc430 ,
tail ,
taillight
