GS400 wheels on IS250 AWD?
Searched but couldn't find any definitive answer --
will the stock 17" wheels from a GS400 fit on an IS250 AWD (which has 17" wheel stock)? No suspension mods on the IS, will be using the stock tire size of 225/45/17.
From what I can tell, the stock IS250 wheels are 17x8, 5x114.3 bolt pattern, +45mm offset.
The stock GS400 wheels are 17x7.5, 5x114.3 bolt pattern, +45 offset.
The only difference appears to be the 1/2" in wheel width. The tire manufacturer (Sumitomo, in this case) lists the acceptable wheel width as being from 7 to 8.5" for the 225/45/17 tire.
Should work fine, right?
netsrac
06-16-24 09:15 AM
