Trunk Light Replacement - NEED HELP!!
Cannot believe I haven't been able to figure this out yet...so I need your help. I bought a bunch of LED's from V-LED.
I cannot figure out how to get to the bulb in the trunk to replace it. Does it require removing the trunk lid lining? If I just pull on the lens, it definitely seems like it wants to break.
I appreciate any advice. Thanks.
hi rtk, u just stick a flat head screw driver and carefully pry out the entire light housing of the trunk light. you can probably do it with your hands, but that is how u get to the light bulb.
its similar to changing out the light on the side passenger / driver door. no need to take off any panels, just pull out the small light housing assembly.
Thanks for the input guys. I will be taking care of this right after work today.
funnie - Thanks for the heads up on the door lights...did you swap out the lens when you changed those bulbs? That is on my short list of upcoming mods, but I was thinking of putting a clear lens in place of the stock cover.
CFL install in ES300
something you might want to consider.
I did the LED swap in my ES300.
I then installed 12"CFL (2 - 12"bulbs in each) each kit cost ~$20 in the Turnk and under the hood.
I've been very happy with the results.
here are the links:
https://www.clublexus.com/forums/es3...-in-trunk.html
https://www.clublexus.com/forums/es3...-lighting.html
here are the links:
