Need Spacers with Eibach Pro Kit?
Old 02-11-10, 07:00 AM
revoappare
revoappare's Avatar
Default Need Spacers with Eibach Pro Kit?
I'm about to make a purchase on some Eibach Pro Kit springs for my 08 Is 250. Do I need spacers? If so, which ones and where can I get them?
Old 02-11-10, 07:06 AM
datplayaz
datplayaz's Avatar
It depends on your rim spec and tire size.
Old 02-11-10, 07:11 AM
revoappare
revoappare's Avatar
I have stock 18" rims. Tire sizes are stock as well. I think the fronts are 225/40/18 and rears are 255/40/18.
Old 02-11-10, 07:20 AM
OutCaster
OutCaster's Avatar
I doubt you'll need spacers with stock wheels and the eibach pro kit.
Old 02-11-10, 07:22 AM
datplayaz
datplayaz's Avatar
You'll only need spacers if you want a more flush look. If I remember right some people are running 15mm front and 20mm rear with their stock rim and tires, you might want to check out some of the vendors on this site who sells them, they can get you a pretty good deal.
Old 02-11-10, 07:25 AM
aQuarius26
aQuarius26's Avatar
I'm running Ichiba Version II Wheel Spacers [R: 20mm F:15mm] with the stock 18's, and I feel they absolutely necessary
Old 02-11-10, 07:43 AM
revoappare
revoappare's Avatar
Thanks for the input guys.
Old 02-11-10, 12:45 PM
JDKane527
JDKane527's Avatar
Same setup here although I rub a little in the rear but I have H&R springs. Definitely looks good with the stock wheels, subtle difference that some people notice.
Old 02-11-10, 07:58 PM
gstenpow
gstenpow's Avatar
aQuarius26 - do your wheels rub any?
Old 02-11-10, 08:48 PM
fasteddy91
fasteddy91's Avatar
I'm running 15mmm across the board, no rubbing here.
Old 02-12-10, 01:45 AM
BrownNight
BrownNight's Avatar
this might sound alil dumb but....
SPACERS = making your wheels look wider or what?
Old 02-12-10, 02:28 AM
k4fu
k4fu's Avatar
aren't there issues with using spacers?
Old 02-12-10, 05:35 AM
aQuarius26
aQuarius26's Avatar
Not as long as they are the ones with wheel studs attached...
Its the ones that are just a plate to push your wheel out and shorten your stock studs that cause problems...
No at all rubbing here... I'm on Tein S-Tech's
Old 02-12-10, 07:42 AM
revoappare
revoappare's Avatar
Hey Aquarius, how much stiffer and uncomfortable is the ride from the eibach pro kits to the Tein s -techs?
Thanks.
Old 02-12-10, 06:04 PM
gstenpow
gstenpow's Avatar
Do you have a good photo showing the profile of the front and rear (showing how far they move the wheels out) with the 15 and 20 mm spacers. I'd be interested in seeing that because I'm thinking of getting those with my G Spider wheels.
Thanks...
Quick Reply: Need Spacers with Eibach Pro Kit?
