Old 12-16-14, 11:34 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
Print Wikipost
DIY: Foglight Modification
Old 03-21-11, 05:08 AM
  #136
swiedom
swiedom's Avatar
if someone would post of wiring diagrams I would like to look at how to wire it to the stalk switch. you gotta be able to do it with relays and such at least.
Old 03-21-11, 05:31 AM
  #137
rL-gT
rL-gT's Avatar
http://www.freefilehosting.net/is250wirediagram
Rofl wow. What a cluster ****. Im gonna have to to disect this
Old 03-22-11, 06:15 AM
  #138
lexus9810
lexus9810's Avatar
Please do
Old 03-28-11, 08:16 AM
  #139
swiedom
swiedom's Avatar
solid! Thanks.
Old 03-28-11, 02:16 PM
  #140
speedywa
speedywa's Avatar
Will this render your fog light switch?
Is the foglights on with drl or alone?
Old 03-28-11, 09:00 PM
  #141
iTaLiAnO
iTaLiAnO's Avatar
the DRLs would have to be on anyways since they come on as soon as the parking brake is released... even if the fog switch worked in any of the three modes, you would have no choice to have the DRLs on unless u pulled them out
Old 03-29-11, 11:48 AM
  #142
speedywa
speedywa's Avatar
So, after you did this mod, you can't control your fogs to be on/off anymore?
they will stay on whenever you start up the car?
Old 03-29-11, 02:52 PM
  #143
rL-gT
rL-gT's Avatar
Yes.
There has to be a way to do this mod like the 300.
Wish I had more time on my hands
Old 03-29-11, 09:40 PM
  #144
iTaLiAnO
iTaLiAnO's Avatar
if u read what i did somewhere between the third and fifth page i believe, i could turn my fogs off by turning the light switch to OFF. apart from that, the fogs were always on.
and for those who are worried about fuses, i replaced the 10 with a 15, and i never had problems. i recently reversed the mod as i was trading the car in to the dealer and the wires were all fine. no burning. so for a simple way to do stand alone fogs with no extra switches go read my DIY
Old 08-28-11, 03:28 PM
  #145
RBL250
RBL250's Avatar
I just did this mod...what i did is i tapped the green wire so my factory fog switch still works....and then i ran the wire i tapped to a switch i put inside my car...on the switch one end was a 12v power line i have ran in the car and i connected the tapped green wire to it....now...wen i flip the switch my fogs will be on...so i can drive with my yellow fogs my yellow high beams and hids on all at once lmao also just my DRL n my fogs...its great
i couldnt find the white wire but i tested the green wire with a volt meter to make sure before i did the mod....
Old 08-29-11, 08:00 PM
  #146
birador
birador's Avatar
will diy mine soon,like driving with both my led daylight and hid fog light together... thanks for the input
Old 02-04-12, 02:51 PM
  #147
XSV
XSV's Avatar
Can someone explain this better? I want to run a switch to be able to turn on/off my fogs. From this it sounds like he tapped into the same wire twice?
Old 02-04-12, 02:55 PM
  #148
XSV
XSV's Avatar
Originally Posted by javyLSU
I had my DRLs disabled right after I rewired my fogs - fogs work perfectly.
No problems whatsoever.
BTW, here's my new switch...
Javier
Did you buy just the switch? or did you buy the switch and harness? Is there a thread that shows you how to install the button?
Old 02-13-12, 10:55 AM
  #149
Vroomin350
Vroomin350's Avatar
I would like to know that too, did you also have to buy a harness for this part #?
84160-04010
Old 02-14-12, 08:39 PM
  #150
ms2619
ms2619's Avatar
someone PM me on how to do stand alone fogs without adding another switch. If I can use the orginial way of just twisting the **** so i can turn fogs on without having the low beams on.
Quick Reply: DIY: Foglight Modification
