Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: Headlight and Fog light Modifications
Overview of popular modifications to customize your Lexus
DIY: Foglight Modification
#31
Thanks, I think everything can be found on ebay.
Now I'm just unsure which kind of wire to use, there are different wires for different amps and Ga..also how to run the wire through the firewall?
#35
Lately I have been reading up on how to do the fog light mod, now according to the various write ups everything seems easy, you find the fog light wire and find a power wire, wire them together with a switch so you can turn them off. ( if you dont the fog light will always be on)
Now here lies the issue, a switch is somewhat cumbersome and isnt the route I am looking for, is anyone aware of a wire that can be tapped into that only supplies power when the ignition is turned on?
Suggestions: Parking light wire, tail light wire, any other you may have in mind
If anyone can help me find the location of these wires it would greatly help.
***Since you found the fog light wire and power wire, im guessing theres a way for you to tell me which wire is the parking light.... id like to tap into that one
Thank you
Thank you
#37
How did u find out which wire was the ignition wire? ideally id like the parking light wire, but if NOBODY has a way of finding it, ill take what i can get lol
#39
ur an all-star. by tapping into the ignition wire, this means ur fogs are always on, and u have absolutely no control over them right?
#42
^^^ any news?
Thank you
Thank you
