Last edit by: IB Advertising
Browse all: Lexus IS Lighting Guides
- Lexus: Headlight and Fog light Modifications
Overview of popular modifications to customize your Lexus
DIY: Foglight Modification
#110
Info about the foglight switches are at 1:40 of this video I shot. BTW, the part number for the fog switch I used is 84480-0E010.
http://www.youtube.com/watch?v=GVf1h95_8rE
Javier
Javier
You said you swapped out the front turn signals for the stobe LED, does it mean the turn signal and strobe light share the same bulb? Must be hella bright at night if it does
#112
i'd like to do this mod but i have a few questions~
when your fog light switch are on, the fog lights stay on regardless right? when you turn on high beam, when you shut off the car? or do the fogs turn off with ignition off too?
when you tap into the wires with the taps, do they taps cut the wire? the reason i'm asking is because i leased my car, and if i need to reverse the process to stock, can i just remove the taps? will the wire still be the same or will it be broken already?
i live in canada.. and apparently the dealership is refusing to turn my DRLs off as they claim it's illegal.. is there a wire i can tap so i can turn the DRLs off myself?
thanks!
thanks!
#113
thanks!
thanks!
When you tap into a wire, the tap will make a puncture like hole in the wire but it will not cut the wire completely. It's like you taking a needle and stab it in the wire kind of deal...
#114
#115
Fog light on/off is independent to engine on or off mode.. according to javier's video, he can turn on his fogs when his engine is off.. That's why he has a switch with a light to let him know that his fogs are on.
i guess then tapping the wires can be reversible by just reversing the tap and no one will really see the hole afterwards?
i might tap the fogs lights somewhere else so i wont have to use a switch
dont want the fogs to be on after the car is off lol or else i might forget to turn the switch off sometime
maybe i'll tap the fogs with the parking lights then tap the parking lights into the DRL.. and use them both as DRLs
hmmm
#117
the reason i wanted to tap my parking lights into my DRLs is cause i want my parking lights to turn on automatically so i don't have to switch the lights when my car is off
another thing is that the dealership won't turn off the DRL for me as it's "illegal" in canada so i'm wondering if there's a wire i can tap into the turn off the DRL but still have high beams?
#119
I am going to give this a try but I am going to try use a 20 amp fuse. One of the techs at my Lexus dealership has had it done in his for about a year with no problems.....will post as soon as I get it done.
