Just got done installing mine today.... fairly straight forward took about 20 min. and yes I disconnected the neg. on battery.... well worth the $30...I`m on stock 18`s with f-sport springs and Hotchkis sways and there is a definite decrease in vibration.
i have luxury pkg with power steering column, and i do not see the side covers of the steering column like 1st post, is there anyone with power steering column have done this mod?
The side covers are there... Use a flashlight and you will be able to locate them.
Installed mine today, steering feels firmer but i realise that my passenger and rear driver power window cannot be controlled on the driver side, anyone can help?
That is what happens when you disconnect the battery. You have to go to each door's window and roll them all the way down and all the way up (from that door) before the drivers door can control them again.
The exact write up on how to do this is in the owners manual.
Also check the sun roofs operation. Sometimes it need to be reset also. (also in the manual)
Thank you so much for your prompt reply, i will try that.
I did not have to do this with mine. I have a 2010 model though.
