Steering Damper?
#226
I installed mine over the weekend, I have to agree with the above. I really don't feel any real difference when turning the wheel, to me it does not feel 'heavy'. However, I do feel a significant difference in vibration which is reduced and makes for a smoother steering feel.
#228
what did everyone use to remove the torx screw. I am trying to use one of those adjustable screwdrivers where you can cnahge the head to a torx, it fits perfectly but its hard as crap to remove because the screw driver is to thick and I cant get a straight angle.
thanks
thanks
#230
I used a TORX insert bit that I chucked in a 3 inch extension on a small 1/4" drive ratchet. Yes it was very tight. You must use something like this as a screwdriver handle will not give you enough torque to loose the two screws.
#233
Just installed mine today. Took 20 minutes, piece of cake pretty much.
Verdict: I didn't immediately notice the difference but after taking it out for a ride, its an upgrade that is worth it, especially for the price! I notice less vibration through the steering and the car 'feels' stiffer. The steering is more responsive as well, I love it!
Note that I didnt use a ratchet for the steering screws, I just used a torx 30 screwdriver.
#235
Over the weekend, I did my first long drive since I installed the damper. Definitely makes a difference when driving an extended time. Hard to place, but your hands don't seem as "tired". Well worth the effort and expense. Also, for those looking I changed from the factory Potenzas to the Michelin Pilot Sport A/S+ tires that have been highly recommended on this forum and I agree 100%. Buying tires is always iffy so I look for others experiences to factor into my choice. I highly recommend these tires if you live somewhere like Indiana weather. Excellent traction and quiet at Interstate speeds.
#236
So has anyone confirmed whether or not the GS damper fits in the IS? Just read through the whole thread and couldn't find a straight answer.
Also, I'm reading people saying this was a $25 mod - I'm seeing $35.07 ($26.00 + $9.07 for shipping) with the CL discount. Is that right?
#240
I installed this at the same time as my aftermarket steering wheel about a week ago. I made a point of trying to notice the difference between before and after, and I think the damper does help with minor road vibrations. However, since my coils are set to full stiffness the moderate to big bumps still come through. I don't regret spending the $40 though.
