Steering Damper?
Old 05-29-10, 03:21 AM
  #91
AznJason
AznJason's Avatar
Originally Posted by IS250TW
Yes you have to disconnect the airbag...
because the wires have to be thru and under the damper
Yep. You disconnect the airbag so the wires can go through, then there's another two connectors that you can easily unplug to get the wires to go through the middle. You'll see when you get to it.
Old 05-29-10, 09:53 AM
  #92
maxframes
maxframes's Avatar
Talking A little tweak
New mod to a mod. I drilled holes on each side and placed lead weights in holes added extra 4 oz overall, real nice feel, matbe a little heavy for some but no match for big manly men like us no??
Old 05-29-10, 10:02 AM
  #93
edgeucated
edgeucated's Avatar
lol i think imma experiment with pennies before i start drilling and doing anything permanent
Old 05-29-10, 10:30 AM
  #94
maxframes
maxframes's Avatar
It is a $30 part be adventurous, takes A LOT of pennies to equal the wt of a lead sinker!
Old 05-29-10, 12:05 PM
  #95
GiantsFan
GiantsFan's Avatar
Thanks...
Is it necessary to disconnect the battery?
Old 05-29-10, 12:07 PM
  #96
IS250TW
IS250TW's Avatar
Originally Posted by GiantsFan
Thanks...
no it's not, leaving the battery plugged will be fine
Old 05-29-10, 04:37 PM
  #97
maxframes
maxframes's Avatar
Red face
No chance of popping the airbag?? I went safety mode and undid battery, sure would have been easier to not lose presets etc.
Old 05-29-10, 07:03 PM
  #98
pocky
mooncake master
pocky's Avatar
Thanks...
ALWAYS a rule of thumb, disconnect the battery when you are working with airbags. It is NOT safe. You might trigger the airbag when you plug the wires back into the airbag module.
It's common sense.
Old 05-29-10, 07:41 PM
  #99
IS250TW
IS250TW's Avatar
It's common sense.
i know that it would be safe to disconnect the battery
but as i've seen other people, they didn't disconnect the battery
but it is true that for safety, its better to disconnect it
Old 05-29-10, 09:57 PM
  #100
javyLSU
2IS OG
javyLSU's Avatar
Please please please disconnect the battery. If you get hit with the airbag while installing this, it could be the last thing you ever do.
Javier
Old 05-29-10, 10:37 PM
  #101
pocky
mooncake master
pocky's Avatar
If you see other people jump off the bridge, yet you know it's not a good idea. You'll do it anyway because everyone is doing it?
This is very dangerous. It's not good advice to tell others it's 'fine' to leave the battery connected while tampering with the airbag.
Old 05-30-10, 01:44 AM
  #102
AznJason
AznJason's Avatar
Do they have a bungee cord when they're jumping? j/k j/k. Just disconnect the negative wire. Quick and easy.
Old 05-30-10, 01:45 AM
  #103
GiantsFan
GiantsFan's Avatar
It's common sense.
Javier
Thanks guys ...
Old 06-02-10, 07:51 PM
  #104
JDKane527
JDKane527's Avatar
Just installed after waiting 2+ weeks because it was on backorder. Took 20 minutes to install it, and took it for a drive. The difference in feel is barely noticeable, but still noticeable. Won't make it feel like turning a 335, but it's better. If only they made it heavier haha.
Old 06-02-10, 08:04 PM
  #105
quang
quang's Avatar
^ interesting... i guess i will pass
Quick Reply: Steering Damper?
