Tires Suggestion Needed~~
Hello Folks,
Finally opening my wallet to get a set of WORKS Emotion CR-KAI 18" rims.
The setting would be as follow -
18x8.5 +38 all around.
What is the best setting for tires without rubbing.
The car just stock setting, didn't do any drop or coilovers.
You suggestion would be much appreciated!!![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
2008 Lexus IS250 AWD
I've liked the OEM Dunlop Sport Maxxs... Dunlop has updated the tire with a Kevlar reinforced sidewall (Sport Maxx TT), and it has been getting good reviews. It outperformed it's competitors in nearly every category in a Tirerack test.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=128
tire size for the 18x8.5 would be 225/40/18 if you want a sorta stretch look but perfectly safe that is what i run, 235/40/18 if you a lil more tire
my front are the 225/40/18 so you can see how it actually is.
my rears are 245/40/18 on a 18x9.5" so you can imagine how the bellow would be with a 245/40 on an 18x8.5" would be.
check out these pix for a reference
Hope this setting will be the best fit for me
225/40/18 that just the stock size right? i want to go with a little bit bigger but not too much. that's why i want to double check with all of you to go with 235/40/18 or stick with the stock size 225/40/18?
Thank you!!
