Please help guys........not sure if I made a mistake.
Hey guys,
I just ordered a set of Work Varianza T1Ss for my SGM IS350.
Here are the specs:
Front: 19x8.5 +38
Rear: 19X10 +38
The fenders will be rolled by an eastwood roller. I am VERY good at this. I did my g35 and 350Z. I damn near had them flush with the body line. It all in the heat.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
anyway, it will be lowered on H-techs or maybe coils. although it wont be very low. Just leveled. The streets of New Orleans are HORRIBLE. So I cant dump it too much.
I am worried that I didnt go aggressive enough. I want to be flush, while not affecting drivability.
Will +38 look ok? Should I maybe go +36? I hate to think I made a $2500 mistake.![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Thanks guys.
Here are the specs:
Front: 19x8.5 +38
Rear: 19X10 +38
Thanks guys.
you did go a tad conservative.
this = flush without going TOOOOO crazy
19x8.5 +22 - yes, your +38 will be very 'sunk in' (use 225 tire)
19x10 +28 - yes your 38 is going to be sunk in a bit there as well. (use 255 tire)
if you JUST placed the order you should be able to make the changes.
Thanks for all of the help guys. I think I misunderstood the real idea of flush, LOL.
I am looking for this setup.
![](https://www.clublexus.com/forums/attachments/is-second-generation/140104d1236478140-new-work-wheels-on-my-baby-1.jpg)
I compared the size KML505 has and what I am getting. After doing the math, I am only off by 3MM in the front. So I will need a spacer in the front to push them out just a tad.
Thanks for the info anyway guys.
