Power window issues ***help***
This morning I started my car and tried to roll down my windows but all my passenger windows wouldn't go down except the driver side window??? I can roll down th passenger side windows with the switch on each individual door but can't roll down the windows with the main switch on the driver side. Anyone have any suggestions???? I still have warranty but I don't have time to take it to the dealer especially if it's an easy fix. Thanks in advance for your help.....(not a good way to start a morning)
wow i got really confused reading that but i think i got it.
did you disconnect the battery or anything lately? typically when you do that, the main switches on the drivers side door panel will not work for any of the windows until you relearn them. basically you have to go to each window switch and roll it all the way down then back up. once thats done, you should be able to use the main switch on your drivers side door.
check your sunroof because it wont be 1 touch anymore til you relearn it also. just hold the open button in til it opens all the way. keep holding the button then after like 5 seconds it will close. that should take care of the 1 touch problem. if not, you may have to do it 2 or 3 times.
