Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
Old 10-17-10, 07:25 AM
  #316
chikoo
chikoo's Avatar
does it do it when it is in 'D' or 'P'?
Old 10-17-10, 09:53 PM
  #317
HKS_IS250
HKS_IS250's Avatar
oh crap i had all of this but changing my spark plugs and cats fixed this
Old 10-17-10, 09:55 PM
  #318
HKS_IS250
HKS_IS250's Avatar
My codes read misfire in bank 2
  #319
HKS_IS250
HKS_IS250's Avatar
shui3000- i have a 6speed
Old 10-18-10, 02:10 AM
  #320
XhyDra
XhyDra's Avatar
Hey HKS_IS250 thanks for the input, did you have the lights flickering when it was rough idling? At how many miles did the cat go bad?
Old 10-18-10, 05:01 AM
  #321
Kurtz
Kurtz's Avatar
Technically, every 2IS is a 6 speed.
Old 10-19-10, 06:33 PM
  #322
Gaugster
Gaugster's Avatar
My AWD is starting to act up a bit. I'm due to change the spark plugs so I might as well do the intake/topend cleaning. Looks like fun....
I guess I'm lucky since I never had any type of issues until now.
What was bad about your CATS that required them to be replaced? Just curious since I don't have the primary ones any more.
Old 10-19-10, 09:17 PM
  #323
BORIS350
BORIS350's Avatar
this problem only knowen on the is250's?
how about is350's?
Old 10-20-10, 05:47 AM
  #324
Kurtz
Kurtz's Avatar
how about is350's?
I've only heard about it in 250s... the presumption is the additional port injection on the 350 avoids the problem
Old 10-20-10, 10:08 AM
  #325
BinaryJay
BinaryJay's Avatar
Lexus has issued the same service bulletin with the same symptoms and correction procedure for the top engine clean for the 06 DI GS as well since the 06 did not have the secondary injectors, I believe the engine is basically the same as the IS250s but with a larger displacement.
Old 10-20-10, 11:17 AM
  #326
MBTC
MBTC's Avatar
The carbon build up and related TSB apply to VINs mid-2010 and prior IS250 models.
Despite all the Lexus enthusiasts here, nobody seems to be able to determine what the production change was. One of life's great mysteries.
I'm astounded that nobody has been able to find out what the change was.
Old 10-20-10, 11:52 AM
  #327
XhyDra
XhyDra's Avatar
If I'm not mistaken someone mentioned exhaust valves and headers being changed in the newer models. Now if only someone with part number insider knowledge can confirm that.
Old 10-21-10, 06:43 PM
  #328
lbaily
lbaily's Avatar
Default It happened to me and I have an IS350
Originally Posted by joshuajj
I am curious if any IS350 owners have run into any of these problems? I know the service bulletin is only for the 250, I wonder why us 350 owners aren't covered?
I own a 2006 IS350 which I bought in December 2005. Last February, I had started accelerating (not quickly) from a stop. When I got up to about 20 mph, there was a loud explosion-like noise and my dashboard lit up with warning lights. I drove it to the Lexus dealership. They told me the engine had a lot of carbon build up, causing a cylinder misfire. There were 5 working cylinders, out of six. It only had about 20000 miles on it, but it was over 4 years old, so the warranty had expired. A $1000 later I picked up the car from the dealer service department. I was not a happy Lexus owner. After I contacted Lexus, they told me it was not part of the valve spring recall, so I would not be reimbursed. At first the mechanic told me the gas I used caused the problem. When I explained to him I only use 93 octane, he said it was an engine design defect. Lexus doesn't seem to agree.
Lexus/Toyota issued another recall yesterday for the IS350, but not for this problem. They should be accountable for the carbon-cylinder misfire defect too. Then I'll have 3 recall notices to take with me to the service department
Old 10-21-10, 07:04 PM
  #329
lbaily
lbaily's Avatar
Default I own an IS 350. It happened to me. Read post #320
I own an IS350. I had major carbon build up, which caused a cylinder misfire and my checking account to decrease by $1000. This is not an IS250 only problem.
Originally Posted by XhyDra
Once again it is very rare for IS350's to have carbon build up. After all the IS250 carbon build up threads it's causing a "non-existing" IS350 carbon build up.
For everyone discussing in this thread or in any other related thread please stick to the topic being the IS250's current issue.
For those that are new, IS250's have been developing carbon in the intake manifolds and in other engine parts due to it's DI (Direct Injection) fuel delivery system. The bigger 3.5l IS350 contains two methods of fuel delivery DI and Port Injection.
Unless someone has a solid case of IS350's having carbon build up and it has been documented by a de-carb at the dealer then share your experience. Until then IS350 owners please stop worrying about carbn build-up on your vehicles.
Old 10-21-10, 08:13 PM
  #330
Clay Easto
Clay Easto's Avatar
What are "cats"?
Quick Reply: Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
