Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
Old 08-08-11, 03:47 PM
  #496
mjhsnow
mjhsnow's Avatar
Default Good news for this problem (Chevron/Techron)
As far as I can tell the rough idle/rpm problem is not coming back--yeah!!!
Lexus has done 3 top end cleanings for this problem. I have 145,000 miles on my 2007. After the last one, i decided to use only CHEVRON 91 OCTANE gas with TECHRON. Before that I had been using mostly Shell gas.
Knock on wood, since i have been using Chevron/Techron, i have had no hint of problem.
Old 08-09-11, 05:16 AM
  #497
is250gurl
is250gurl's Avatar
I too have been using chevron with techron since my cleaning at 35k and at 61k now it hasn't done it again although it still idles rougher than it use to. I feel vibration at stops. Whenever I get a new loaner I always notice it more then...no vibration in the steering wheel or on the door. Oh well other than that a solid ride!
Old 08-09-11, 10:46 PM
  #498
prankster
prankster's Avatar
I did a seafoam treatment last week @62k. I saw a faint of white smoke from the exhaust. I was very disappointed. $10 for insignificant amount of carbon build up. I can't tell the difference before and after treatment. Yes, I did it because I read so much carbon build-up issues on IS250s . I don't have rough idle issue to begin with to be honest. And yes, I've done seafoam treatments before to my previous cars. I saw much worse smoke on my miata.
I guess there is a little bit difference between AT and MT cars. It seems that most carbon issues are affecting IS250 cars with AT. But I could be wrong.
Old 08-09-11, 10:52 PM
  #499
MBTC
MBTC's Avatar
I read this a couple of times and still don't quite understand. Nothing was wrong originally, but you spent $10 to fix it and was disappointed when the fix did not expose a more expensive problem? Truly not trying to be a ****, just hoping to understand what you mean. I've got a 2010 250AT which "supposedly" is immune to the problem, but I'm not sure to what extent so I'm keeping a close eye on it. Appreciate any comments.
Old 09-10-11, 04:51 PM
  #500
XhyDra
XhyDra's Avatar
Slight UPDATE >.<
I want to chime in a little bit of inside knowledge that I've been inquiring for some time now. After feeling like I've been on the queue for what seemed like eternity there's now a chance of an answer.
According to some inside sources which I cannot confirm or deny what I've been told, Lexus is well aware of this issue past the TSIB fix for it. Apparently there's talks of having a short block rebuild with certain components changed, anywhere from pistons to valves. I'm not in 100% certainty of what is exactly being looked at but there is talk that this will become another recall to adress this issue permanently.
If I come across more of this intel I will update this thread.
Old 09-12-11, 05:10 PM
  #501
freeflight
freeflight's Avatar
Good to know there is a LSB for this issue.
Old 09-12-11, 07:34 PM
  #502
Gaugster
Gaugster's Avatar
It's a problem, no doubt about it. Here's my crappy photos from when I did the T.E.C.
http://s432.photobucket.com/albums/q...ion%204GR-FSE/
I don't have a Chevron in my area but add a Techron additive every 1500 miles or so. I can see lots of black carbon on hard accel but its hard to know if its the additive removing carbon from the engine OR normal carbon build up that settled within the exhaust pipes.
My cars fast so I gots to be doing something right.
Old 09-14-11, 11:25 AM
  #503
XhyDra
XhyDra's Avatar
It appears that some members are already having this new unamed service bulletin performed on their car. One whitch involves replacing pistons and I believe valves as well... This just got a whole lot more interesting.
Old 09-14-11, 11:33 AM
  #504
is250gurl
is250gurl's Avatar
very interested in this as i had the first tsib done around 40k and now at 62k it's sputtered again a few times on me in the last few months. need the spark plugs changed also so if something comes out i will get it all done asap at the same time.
Old 09-14-11, 07:14 PM
  #505
CCJ22
CCJ22's Avatar
Mine shakes like an earthquake for 2 seconds then goes away whenever I idle at a light.
It occurs very very randomly.
Old 09-14-11, 11:45 PM
  #506
XhyDra
XhyDra's Avatar
Here's the official news some of us have been waiting for, finally a solution to our little Carbon issue. I've confirmed with a Master Tech friend of mine and what is being replaced according to Lexus's service bulletin is pistons and piston rings.
More info when I come accross some.
Looks to me like I'm getting an engine overhaul
Old 09-14-11, 11:54 PM
  #507
CCJ22
CCJ22's Avatar
Looking forward to you getting your hands on the TSIB #.
Thanks for your contribution in this thread.
Old 09-15-11, 05:07 AM
  #508
is250gurl
is250gurl's Avatar
so glad to hear this!
Old 09-15-11, 10:13 AM
  #509
tedward88
tedward88's Avatar
nicee...but if i had to guess, its only for people who still his their car under warranty right?
Old 09-15-11, 11:05 AM
  #510
is250gurl
is250gurl's Avatar
don't know how that would be fair as it's a design flaw and their fault
Quick Reply: Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
