Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
Old 09-27-11, 05:07 AM
  #511
meangene
meangene's Avatar
I took my car in last week for an oil change and for them to check on the carbon build-up issue. I haven't picked up my car yet, but they sent a service order to my email.
It looks like they want to replace a few parts
CONFIRMED BY TECHNICIAN (DIAGNOSTIC SPECIALIST): DOCUMENTATION PAPERWORK GENERATED AND SUBMITTED: MANUFATOR COUNTERMEASURE MAY BE REQUIRED :R/R PISTONS/PISTON RING SET, VALVE SPRINGS & VALVE LASH ADJUSTERS:FINAL APPROVAL AND PARTS PROCUREMENT PENDING; GUEST WILL BE NOTIFIED AND RESCHEDULE
Old 09-27-11, 06:06 AM
  #512
APynckel
APynckel's Avatar
Does this still occur if you use premium gasolines?
Old 09-27-11, 06:44 AM
  #513
Kurtz
Kurtz's Avatar
Yes... most lexus drivers use premium anyway, and the issue is that fuel never touches the problem area... which is why the 350 doesn't have this problem (it has additional port injectors so fuel DOES hit that area)
Old 09-27-11, 06:49 AM
  #514
hades281
hades281's Avatar
I don't know what new piston rings will do to keep the valves clean... It is hard to imagine that essentially a full teardown and rebuild of the engine is the fix for all of the IS250's out there with these symptoms. What a nightmare -- and though the dealerships to seem to have good service shops, it's a complicated job and I don't know how I would feel about my engine being overhauled.
Old 09-27-11, 07:10 AM
  #515
meangene
meangene's Avatar
Ya thats exactly how I feel. I'm not even sure if my dealership has done one of these yet. He just kept saying the parts aren't available. I really don't want to be the guinea pig...
Old 09-27-11, 07:17 AM
  #516
APynckel
APynckel's Avatar
Got the TSIB number for you guys
L-SB-0068-11
Coming from Tim (services manager at Sewell Ft Worth):
Sea foaming your engine, and / or installing a catch can between the PCV and the intake pipe will help as far as preventative maintenance goes.
Old 09-27-11, 09:32 AM
  #517
XhyDra
XhyDra's Avatar
L-SB-0068-11
It's funny you say that, after cleaning my intake and throttle body the one major thing I noticed was how much sludge was built up on the intake pipe and the throttle body. I mean it was black and gritty. I'll post some pictures up as soon as I get a chance. I've been looking at the best solution as far as a catch can is concerned. A little DIY on throttle body cleaning and catchcan install coming soon
Thanks for listing the L-SB for the new service.
Old 09-27-11, 11:26 AM
  #518
hades281
hades281's Avatar
L-SB-0068-11
Can anyone post up this LSB so we can read it??
Old 09-27-11, 11:50 AM
  #519
TheSenator
TheSenator's Avatar
What do you guys think about this "catch can" thread?
https://www.clublexus.com/forums/is-...catch-can.html
Old 09-27-11, 03:23 PM
  #520
APynckel
APynckel's Avatar
I think that "catch-can" thread is full of bad advice. The engine will continue to draw in oil vapor from the PCV as long as there is a + pressure differential between the crankcase and the point source for the PCV on the intake tract. The engine will create a venturi, drawing in vacuum from the intake pipe, and this will further increase the work done removing crankcase vapor from the block. The more ventilation you have in your block, the BETTER. If you plumb a catch can (with an integrated baffle system to cause the vapor to fall out of suspension) in between the engine and the vacuum source, it will collect the otherwise harmful vapor from entering your plenum and depositing / coaking on your valves and other engine parts.
Here is a picture of the catch can setup on my DSM
The turbo creates a MASSIVE vacuum on the crankcase, and it actually increases horsepower, because the rings seat better, resulting in a more efficient power stroke due to the containment of the combustion.
The only thing I could do to better this setup, is to get a 2ndary catch can, and run it between the head and the intake manifold, with a check valve, so that under idle / cruise (off boost), the engine will see the benefit as well.
Old 10-01-11, 02:45 PM
  #521
fjascione
fjascione's Avatar
Default carbon problem?
any update on the new TSB....here im here south florida waiting for parts to come in. Thats what the rep said. I am curious as to what the "fix" is on our cars...the other TSB's dont fix the problem
Old 10-01-11, 06:13 PM
  #522
jay90011
jay90011's Avatar
Don't know the tsb but just know that the piston rings are being replaced . My car is the ginnie pig at the dealer just dropped it off Saturday and they did not give me an estimated date on when to pick it up. They just said it would be over a week or two. I'll post up my sevice summary when I pick it up.
Old 10-02-11, 03:04 AM
  #523
CCJ22
CCJ22's Avatar
Which dealership and are you still under warranty?
Old 10-02-11, 03:34 AM
  #524
KillaIS250
KillaIS250's Avatar
Say what. Free engine overhaul? lol
Someone post the TSIB please, i can't find it searching from the number already posted
I was just about to call the dealer tomorrow and let em know my cars been having the shaky/rough idle again just after 20k miles. But if there's a better fix for it now im interested!
Which dealer did you take yours too?
Old 10-02-11, 12:53 PM
  #525
chikoo
chikoo's Avatar
This new L-SB sounds weird.
New Piston rings to help with carbon buildup on intake valves?
Sounds like accupressure treatment to me. Fuzzy at best.
Quick Reply: Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
