Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
Old 02-22-12, 07:14 PM
  #721
autox250
autox250's Avatar
Originally Posted by sktn77a
2008 IS250, 45000 miles, about to go out of 4 year limited warranty. Had a very slight rattling noise under light acceleration from cold (never really went away but got less when the engine was hot). Didn't have a significant hot idle problem and the car never misfired or threw a code.
Dealer called today and they are going to do the piston ring fix. I was a bit leery of this as the noise was minimal but they said it would only get worse. Will post when I get the car back.
Based on your description it sounds like piston slap, they all do it cold its normal operation
Old 02-23-12, 12:14 PM
  #722
sktn77a
sktn77a's Avatar
Possibly, but I don't think so for several reasons:
1. The car didn't do it when new (started noticing it at around 35k).
2. No other IS250/ES350 I've driven makes this noise.
3. I don't think Lexus would replace an engine (essentially) unless they were confident there was a problem.
Let's see what happens.
Old 02-24-12, 08:02 AM
  #723
J3ffrey
J3ffrey's Avatar
apparently I've got a new shortblock
Sooo I got the car back.
They replaced the water pump
Sounds good, starts right up as usual. Power feels the same. There's some new noises though. A higher pitched fan/pump kind of of sound (new water pump maybe?)..
One major difference is that my brakes now suck. They used to be so touchy and I could NEVER get it to the floor, now... I have to push real hard on them to get some real stopping power AND I can hit the floor.
Old 02-24-12, 10:13 AM
  #724
jay90011
jay90011's Avatar
I noticed the same thing after the repair. Bleeding my brakes this weekend so hopefully that makes it feel better. My brake pads are still pretty much new just changed them out about 7k miles ago and bleed the brakes as well then.
Old 02-24-12, 10:49 AM
  #725
ac2000
ac2000's Avatar
Could someone post the TSB please? I have a 2011 IS250 RWD. thanks
Old 02-24-12, 10:55 AM
  #726
J3ffrey
J3ffrey's Avatar
I sure hope it doesn't apply to your car!
Old 02-24-12, 11:07 AM
  #727
J3ffrey
J3ffrey's Avatar
Did you have the block replaced? Or just the rings/etc.
Old 02-24-12, 11:18 AM
  #728
Kurtz
Kurtz's Avatar
Yeah If your brake pedal is going to the floor it sounds like the brake lines were not properly bled.
You ought see to that. Quickly.
Old 02-24-12, 11:32 AM
  #729
J3ffrey
J3ffrey's Avatar
I sent the service adviser an email letting him know about the problem so at least he knows what happened. I'm sure after all the work they did on my car they were just ready to get it the F out. Even though that's no excuse for not bleeding the brakes, I might as well just do it myself tomorrow.
Old 02-24-12, 12:47 PM
  #730
autox250
autox250's Avatar
The brakes are not touched they stay in the car when you drop the subframe w drivetrain... Its weird that it happened to u.... As for the short block, its not part of any bulletin, so there had to have been something more to it.. I have the bulletin in pdf format
Old 02-24-12, 12:49 PM
  #731
autox250
autox250's Avatar
I finally opened my engine to check the valves n used a bore scope to see the pistons ill post pics tonight. The valves didnt improve that much but the piston domes are totally clean 66k and no trace of carbon! I ran 16oz gm to engine clean, 32oz toyota engine clean + 16oz washer fluid @ 4k rpm. In the last week my fuel trim is down to 2.1%... damn near perfect.. I doubt ill be seeing any misfires for a long time
  #732
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The bulletin mentions replacing the short block if there is any scoring on the cylinder walls, or there is not enough visible cross-hatch. It says not to hone the block, but to replace it.
Jeff
Old 02-24-12, 01:05 PM
  #733
J3ffrey
J3ffrey's Avatar
Jeff
yes, there was scoring on #3 walls.
can you tell me what else comes with a short block? Does this mean all the pistons/crank/etc were also new? Or did they remove old parts and use them in the new block ? Stupid stuff like Sparkplugs are not listed on the invoice.... but I'd like to know if they were changed.
I should have asked my adviser but he was busy.
Old 02-24-12, 01:17 PM
  #734
jay90011
jay90011's Avatar
i had the rings replaced the first time , The misfire continued so they replaced the block the second time around.
Old 02-24-12, 01:27 PM
  #735
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Short block is the block, crankshaft, rods, and pistons; assembled.
Bare block is the block alone.
Jeff
Quick Reply: Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
