Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
Old 04-10-12, 04:50 PM
  #841
KillaIS250
KillaIS250's Avatar
Originally Posted by 250user
I was like you I never thought too much about it at first. I can't believe the problem is still in a 2009 is250.
Does anyone know what the time limit or mileage limit is to try and file a lemon lawsuit???
In CA I believe the statue of limitations is at 4 years for filing a lawsuit against the manufacturer under the Lemon Law.
As far as getting a car buyback, I think it's still set at 3-4 attempted repairs to the vehicle for the same issue to get it taken back under the CA law. Someone told me at least the first repair has to be while it was still under manufacturer warranty (4yr/50k) to have a solid case.
Old 04-13-12, 01:58 PM
  #842
juvi22003
juvi22003's Avatar
Dropped my car off on Wednesday at the dealership to be checked out for the carbon build-up, just got a call back today from the dealer today that one of the cylinders are miss firing and they will be putting in new pistons.
Is this another sign of carbon build-up?
Old 04-13-12, 05:53 PM
  #843
600rr05
600rr05's Avatar
sounds like it. i had the same issue and i was told that by replacing the pistions and rings the build up shouldn't happen but we will see. Gotta admit though ever since i got my car back it does drive a lot better.
Old 04-13-12, 07:30 PM
  #844
J3ffrey
J3ffrey's Avatar
honestly... after a "shot block replacement"
I think the vibration when I'm sitting at a red light in Drive ......... is way worse than it was before bringing it to lexus.
The start up cam gear noise is still there (even though they swear it isnt) and there have been a few times where I STEP on the gas hard and the car hiccups for a second before it goes.
This is why I like my 6 speed camaro for "go" situations... it has an actual metal wire that goes to the throttle....you press the pedal and it goes...
Old 04-13-12, 09:15 PM
  #845
Noeh
Noeh's Avatar
how many miles did you guys put on your cars before rough idle/misfire started?
Old 04-13-12, 09:40 PM
  #846
juvi22003
juvi22003's Avatar
Did they replace all your pistons?
Old 04-13-12, 09:42 PM
  #847
juvi22003
juvi22003's Avatar
I heard/felt mine around 60k i heard it more after i installed my exhaust.
Old 04-14-12, 02:18 PM
  #848
codenko
codenko's Avatar
mine started at around 39k
Old 04-16-12, 08:25 AM
  #849
Thinktwice
Thinktwice's Avatar
To claim its a lemon over this issue is a bit of a stretch IMO. It's almost like using the lemon law to sue because of a vibration noise in the trunk that they couldn't figure out. It's more of an annoyance than anything. I can't say this issue has ever really affected drivability for me as it's extremely intermittent and only occurs when idling. It's not like cars are stalling when driving 60 on the freeway.
Old 04-16-12, 12:07 PM
  #850
Sango
Sango's Avatar
Does anyone have a PDF of the TSB or TSB# for this?
Thanks
Old 04-16-12, 04:58 PM
  #851
SCV8
SCV8's Avatar
Water injection, premium gas, and some oil that's better than what they use at the dealer, high detergent anyways. I still like those engines, even though a former Toyota tech told me to stay away.
And here I was looking for the next family car that might have the same character as my old SC...
Old 04-16-12, 10:45 PM
  #852
ILL250
ILL250's Avatar
does anyone have a rough estimate of how much it would cost to fix this problem? Im out of warranty and my car is starting to have the shaking issue once in a while.
Old 04-17-12, 02:00 AM
  #853
KillaIS250
KillaIS250's Avatar
Via top engine clean or do you mean replacing the pistons with the new ones?
I can look up how much my warrantied top engine clean was billed to Lexus for if you want to know that.
As far as getting pistons replaced, its probably a CRAZY repair bill. lol
Old 04-17-12, 04:59 AM
  #854
HennessySK
HennessySK's Avatar
Keep in mind that warranty cost is much less than customer pay cost. I worked up an estimate, and customer pay engine rebuild with new pistons and piston rings would cost $9575.
If the cylinder walls have deep scratches, it would also need a short block - $7200. (minus $2050, because new short block comes with pistons & rings)
Old 04-17-12, 07:20 AM
  #855
zen
zen's Avatar
get a warranty if you are thinking to get a IS 250, an extended warranty is even better.
I have extended warranty covered for 5 yrs from 2011 and 125,000 miles.
Quick Reply: Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
