Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
#991
I am starting to doubt the truth about his post. He posted on here that he has an 06 250 with 250,000 miles on it with minimal problems. He said he put 250K miles on his car in 5 years doing CITY driving. Taxicabs are the only cars that could possibly put 50k miles per year in city driving. I am calling BS.
#993
Is this the point where you call corporate directly and mention that you are considering consulting a lawyer as well as calling the auto journalist for the local paper to run your story? Given Toyota's recent past, they will do whatever is reasonable to avoid negative publicity.
The local dealer is only going to do so much for you. If TSB states that they should have replaced the lower block originally and they didn't, any subsequent labour as a result of the rework would be their cost, I can see them playing the "corporate said no" game to avoid re-doing the work.
#994
The dealership bought my car back and I leased a 2012 IS250. I figure if this one has carbon build up, I just turn it back into the dealership at the end of my lease and it's not my problem. They gave me a smokkkkkkin deal because of what their mechanic did. I had to take my stuff out of my old car that they had in the air in the service dept. I walk in with my boyfriend and see my entire exhaust system, drive train, and engine dismantled and underneath my car. The exhaust was completely coated in a nice, thick layer of soot from the mechanic's screw up. I'm so glad I got out of that car because I know it would have led to more headaches down the road. I had twenty service records in the 8 months I had the old car... no thank you.
Love, love, love the new car.
#995
#996
Check out this video of the BG product, I think thats the only cheap solution not to stop it but maintain it as best as possible without going inside the engine, interesting vid http://www.youtube.com/watch?v=biM5-GW4CLQ
#997
Don't hate me for the plug, but check out Part II as well. It was crazy how much smoke spewed from the exhaust. Would it work for your vehicles? I'm not sure, but I'm game to give it a shot if anyone is interested.
http://www.youtube.com/watch?v=-JvCt...feature=relmfu
There are many cars with DI engines, some just need to remove the intake manifold to clean the intake valves, like BMW N54/N55 used in 135,335 etc. I think it's a little more work for the IS250.
#998
I thought the smokes should be black from carbon deposit when it blows out the exhaust, in the video it seems white smokes come out. is it just clean the fuel injectors ?
#999
I posted the situation a few posts back. It was a 2008 IS50 with 54,500 miles. I brought my car in for the engine tear down and three weeks later I picked my car up. It was smoking out of the tailpipes when I started the car so I called my service adviser and he said it was normal and just the chemicals from the cleaning burning off. I went on a test drive with my mechanic right after I got the car back because my alignment was off when I took my car back and the steering column was creaking when I turned right. Dude smelled like weed really bad. I told my SA when we got back and had faith he'd take care of it. I brought it in after three weeks and demanded they keep it and figure out what was going on but they had to do another tear down to find the problem. Pistons 1 and 3 were filled with oil. My mechanic had piston 1's rings lined up perfectly when they should be staggered by 120 degrees, piston 2's rings were in upside down, there was gas in my oil, and oil was coming out of my tailpipe. I knew the exhaust system had to be all throughout the exhaust system if there was oil coming out of the tailpipe and the engine could have long-term damage that was caused by their mechanic who was most likely high during the reassembly. Therefore, I demanded a buyback.
#1000
![EEK!](https://www.clublexus.com/forums/images/smilies/eek.gif)
#1001
#1003
nope your wrong it is caused by carbon biting, (carbon lands between exhaust valve and seat) causing exhaust leak, low compression and eventully a missfire.
#1004
I did the cleaning manually at a garage isn't it the easiest way to deal with it or i should be worried? btw my friend sprayed something he called "intake cleaner" in my intake valve and saw black smoke coming our of the exhaust not that much though..
