Lexus IS250 4GR-FSE Engine Carbon Build-up (merged threads)
#1096
#1098
Your engine will be removed and disassembled down to the crankshaft. Each piston head and its rings will be replaced. The engine is then reassembled and installed in the car. A leak check is then done followed by a test drive of more than 10 miles. I usually go about 40 myself. And if all goes well and no codes return, the car is returned to you. Is this a permanent fix? Only time will tell.
#1099
For those that have followed this entire thread, i've posted my belief as to what is the simple solution in these cars since they do have a 7th injector, and my belief that there is a correlation between carbon build up and average temperature - in colder weather the 7th injector runs and cleans the valves.
My original solution was a signal intercept that would run the 7th injector on start up for 30 seconds or possibly something like a turbo timer that would run the 7th injector before shutting down. It was complicated due to the requirement that you'd need to also intercept the signal to the cyl. injectors to shorten duration slightly so that it wouldn't have an error read by the o2 sensor.
i'm curious to know how many IS250 owners up in Canada are experiencing carbon build-up issues. In our local climate, i would say we are below freezing temps for at least 4-5 months a year, and in the deepest of winter months, where we reach temps of -35C, our cars take forever to reach operating temp.
If we do in fact have a 7th injector that does spray fuel at the valves, and people are using shell up here with all the cleansers etc., maybe our valves stay cleaner since half the year we are driving with that 7th injector running for quite a bit of time, whereas owners in the sun 350 days a year aren't as able to utilize that extra injector since the car doesn't have too long of a cold-start up.
is that reasonable thinking or am i just out to lunch? i'd definitely be interested to see...
for right now our IS250 is at 84k KM (54ishK miles) and i have had no instances of the dropped idle, rough idle, shaking etc.
#1100
#1101
#1102
I'm in Toronto and have had the rough idle issue for a while. Doesn't happen all the time though. Back in June I even had the check engine, vsc, etc. lights issue and the care barely limped through the intersection. Once through I parked and turned the car off and back on a few minutes later. No lights and car drove normally. No reoccurance of that but still have the occasional rough idle issue.
Finally took the car in today (Been working out of town and this was the first opportunity). Anyway dealer called and said they could find no codes or anything else wrong. They are keeping the car overnight and will test it again tomorrow. I'm not optimisitc, or happy. Only have 2 months remaining on the extended warranty. If this happens and they finally find an issue would they repair even if out of warranty? Anyone one up here pay for a top engine clean and if so, how much did it cost?
Thanks
Thanks
#1103
Hey @totalstu, i also have an AWD 07 and i took it in for rough idle and was told that there are no error codes coming up. Lexus Oakville was the dealer. I'm planning to take it back then talk to Lexus Canada.
Is yours having an intermittent issue at idle? Mine is just rough idle with the vibration felt in the steering column and seat, it does it all the time though... Good luck
#1104
Good luck with yours. Keep us informed.
#1105
Thanks
Thanks
#1106
It is very obvious when a coil is disconnected - codes specific to the coil are thrown that aren't when it's carbon.
#1108
Got the car back. Dealer could not find anything wrong. Told me to monitor it and right down details, like engine temps, weather conditions, etc when it rough idles. Maybe I'll get lucky and it will check engine thingy again. Anyone up here ever do the top engine clean out of pocket and if so, how much did it cost?
BTW, I'm not doing the ignition coil trick, whether it may work or not , as i'm not skilled enough to attempt.
PS after 1.5 days in an ES350 i'm glad to have my is250 back.
#1110
well yesterday i think i got my first taste of this. my fiance was driving when all of a sudden she says whats wrong with the car? we weren't at a light or anything, we were just driving along a normal road after exiting a freeway, but no stop. it started to shudder a bit, and she said it felt like we were running out of gas or about to stall, power cutting in/out.
The check VSC came up on the display, traction control light was on, and the CEL was flashing. we limped up to the next light and shut the car off and turned it back on and of course everything back to normal. We'll be taking it to the dealer tomorrow as soon as they open to see whats up.
I want to like this car so much but these things definitely scare me especially with us having bought this used. We are still under powertrain warranty until middle of next year, so hopefully we can enjoy this car the way its supposed to be!
here is what our cluster area looked like...
![](http://i240.photobucket.com/albums/ff6/aznives3/6E2D457A-64E7-429F-AB4F-4634091EB96C-5203-000004FC440E378F.jpg)
