door light ---> led strip DIY!
Old 02-26-10, 04:47 PM
shiny250
shiny250's Avatar
Default door light ---> led strip DIY!
Hey guys so heres the DIY that was requested by some members. Enjoy!
1. First pull off the red light cover using your fingers. Start at the bottom edge of the cover and it will pop off.
2. Then pull off the clear bulb cover using a screwdriver to push the tab. The cover will pull right off after. Pull out the stock bulb if you don’t want the red light to remain on after the led strips are installed. Then push the grey tab that connects the red cover to the power source. The cover will come off.
3. Then pull the paper off the led strip and place it where you want. Mine started from half way up the door to all the way to the bottom of the door near the body of the car. (the pic shows the leds on but theyre supposed to be off. i didnt really take apart the whole set up haha sorry)
(If you buy a 3 ft led strip keep reading. If yours is shorter then you can skip past this)
4. I had to run extra wire to make the led strip cable reach the power source. Cut however much wire is necessary. Then attach one wire to the + end of the led strip and one to the – end.
5. The strip had no problem sticking to the black plastic on the side of the door, but had trouble sticking to the metal underneath the door. So I used some high performance double stick tape to adhere the two together. Then run the wire under the rubber weather strip.
6. The blue wire is the + and the light green is the -. Use a razor to cut off a small half inch section of the insulation surrounding the each wire.(this is where you will tap into the power source for the leds)
7. Connect the + end of the led strip to the blue wire and then twist it for a good connection. Tape the + connection with electric tape tightly so it doesn’t slip off. Then twist the – wires together and tape them. (the dark green is the extra wire i cut so the power source would reach the leds cause the provided wires weren't long enough.
8. Reassemble everything and enjoy!
Happy modding
Old 02-26-10, 04:54 PM
LycheeXD
LycheeXD's Avatar
Thank you!!! :d
Old 02-26-10, 05:14 PM
iSuxeL
iSuxeL's Avatar
I'd recommend that you redo your wiring.
Old 02-26-10, 05:19 PM
Initial_K
Initial_K's Avatar
How about when it rains or during a carwash?
Old 02-26-10, 05:25 PM
shiny250
shiny250's Avatar
any reason? ive had them on for about 10 months now and nothings gone wrong. whats wrong with it?
and as for rain n car washes. no water gets anywhere near there. its rained hard here early this month n the car has gone through countless washes, and still as good as new
Old 02-26-10, 05:29 PM
Vincent123
Vincent123's Avatar
i can dig it, looks good
Old 02-26-10, 05:51 PM
iialcii
iialcii's Avatar
looks pretty neat. nice
Old 02-26-10, 07:28 PM
DJSirkit13
DJSirkit13's Avatar
i wouldn't have gone all the way up the door just the bottom would look clean
But what ever works for u I guess
Old 02-26-10, 07:30 PM
Hoovey689
Hoovey689's Avatar
props to you for a unique mod
Old 02-26-10, 07:32 PM
iSuxeL
iSuxeL's Avatar
I'm just **** I like to use heat shrink tubes when I do wires. Looks cleaner and extra security.
Old 02-26-10, 07:43 PM
plusone
plusone's Avatar
i agree with isuxel. i would of used t-taps and all fir a much cleaner install. but props for doing it. looks sick at night.
Old 02-27-10, 01:38 AM
Jetfire
Royale with cheese
Jetfire's Avatar
thanks for the diy.
Old 02-27-10, 05:03 AM
ecr527
ecr527's Avatar
for originality. I'm guessing that doesn't get pinched when you close the door??
Old 02-27-10, 07:00 AM
iLexi
iLexi's Avatar
Ditto.
Old 02-27-10, 01:57 PM
shiny250
shiny250's Avatar
hmm yeaa good point. i think ima do that instead! hahah
nope no pinches. the led strip is super flat so it doesnt have any chance of even touching the body of the car when the doors closed.
btw i love the look at night when you see the leds come up the door. if its just under the door it looks like an underglow, which is not what i was really looking for. but to each his own right? thanks for the input guys!
Quick Reply: door light ---> led strip DIY!
