HELP - Beeping from dash area
I have an 07 IS350 with 15000klms. (~9000 miles) on it. Recentlly after starting and in reverse, backing out of my garage there were three regularly spaced beeps from the dash area. This happened again on a couple occasions. It happened again when driving at about 30 mph. Can't remember if road surface was wet or dry. Very puzzling. Any ideas as to cause and fix.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I am guess it may be the vsc. When ever the vehicle detects no traction it engages it and i think the beeps it cause of that. Did u see the traction light on your dashing blinking when the sound comes?
More help is appreciated.
My VCS will beep if I come to a stop on a pitch and roll back a little while still in Drive. This freaks out the car even though everything is under control. Are you on a pitch at all?
I have an 07 IS350 with 15000klms. (~9000 miles) on it. Recentlly after starting and in reverse, backing out of my garage there were three regularly spaced beeps from the dash area. This happened again on a couple occasions. It happened again when driving at about 30 mph. Can't remember if road surface was wet or dry. Very puzzling. Any ideas as to cause and fix.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
