Wheel studs on wheel spacers broke off into Lugs nuts
Old 03-05-10, 09:57 PM
r6ownz
r6ownz's Avatar
Default Wheel studs on wheel spacers broke off into Lugs nuts
So I escaped from a huge and major accident a few days ago...as I was driving I heard this really loud thud noises coming from my passenger front tires so I quickly pulled into the nearest parking lot to inspect the tires. Thinking that I may have a flat which was highly unlikely cause I just recently checked the air on them (no tpms). What I saw was really scary...four of my lug nuts were missing and the only lug that was intact was the wheel lock which was really loose. So it turns out that the wheel stud on my wheel spacer broke off into my lug nuts. What do you guys think I can do about this? Do I try to get a new set from Ichiba for free?
Old 03-05-10, 10:01 PM
phongh
phongh's Avatar
Wow that's crazy. I'm not sure they will exchange you for another set. I think you better without spacer and extended stud.
Old 03-05-10, 10:02 PM
r6ownz
r6ownz's Avatar
Old 03-05-10, 11:24 PM
BADFNZ
BADFNZ's Avatar
Who torqued your lugs last and was it done with a torque wrench or impact?
Old 03-06-10, 08:23 AM
jeronimus
jeronimus's Avatar
wow, this is scary. I actually spent extra for my Kics thinking this is the top brand. I wouldnt go cheap with them spacers.
Old 03-06-10, 08:29 AM
TLe2006
TLe2006's Avatar
Did you run over a pothole? It should cover under warranty since the studs broke off.
Old 03-06-10, 08:34 AM
nmpeter
nmpeter's Avatar
They were probably over torqued.
Old 03-06-10, 08:46 AM
iRock
iRock's Avatar
That is crazy. Lucky u pulled over. I'm thinking it should be warranty
Old 03-06-10, 09:48 AM
mxis350
mxis350's Avatar
wow thats scary. Why you running spacers?? Dont tell me its because of DYNA's or ill ***** my pants cuz i just got them.
BTW sense you dont have TPMS eather, did you find a way to turn of that stupid "check system" warning??
Old 03-06-10, 10:19 AM
R6_Dude
R6_Dude's Avatar
Your lugs might have been put on too tight. Scary situation, glad you are ok.
Old 03-06-10, 11:44 AM
sinister2c
sinister2c's Avatar
dont trust those space studs...who knows where they were made and how. see if you can put some OEM ones back in.
Old 03-06-10, 11:54 AM
xuningshen
xuningshen's Avatar
as people has said, over torqued lugs, did a shop install the spacers or did you tighten them yourself?
Old 03-06-10, 12:31 PM
istundra
istundra's Avatar
knock out those lugs and press some new ones in place. Yes, ichiba spacers have weak lugs.. but that damage may be from over torque.
Old 03-06-10, 07:13 PM
r6ownz
r6ownz's Avatar
I used an impact....nobody else does work on the car except for my cousin and I
Old 03-06-10, 07:14 PM
r6ownz
r6ownz's Avatar
No pothole at all...I've had these on for a while, I cant remember when but I've had them on a few weeks before I posted pics of my car with the wheels on.
Quick Reply: Wheel studs on wheel spacers broke off into Lugs nuts
