Factory HID's
ok so i got yellow fogs and i already have the oem hid option can someone explain to me the different lights i know fogs high beams daytimes which are in the high beam housing and just the regular headlights is this right and which ones of these are hids
Your low beams (D4S) are the only HIDs in your car. They are bi-xenon, meaning when you switch to high beams, not only does your high beam bulb turn on (a 9005 bulb, which doubles as the DRL), but a shield moves allowing your HID low beams to shine higher.
You also have a parking light in the same housing as your lowbeam (a 168 bulb). You should replace this with an LED to match your HIDs. Finally, you have your fogs (9006). There's turn signals too, but I don't know of many people modding those.
Hi guys, is there a difference between d4s/h11?
which one is the correct bulb that I should buy if i were to change my bulb for my factory HID?
according to https://www.clublexus.com/forums/is-...ng-mods-3.html, it says lowbeam = h11
but this thread tells me to get d4s.
also, the DRL is the high beam right? so if I were to change my DRL, i would buy 9005 bulbs?
JerZyLS430
09-06-14 04:08 PM
