Removed the battery - alarm screaming. Quick help needed!
Old 03-13-10, 04:27 AM
Tomasu
Tomasu's Avatar
Default Removed the battery - alarm screaming. Quick help needed!
The battery of my car died because I forgot to turn off the dome light. I decided to remove the battery and recharge it. Now the whole car goes crazy when I try to put it back. It doesn't recognize my keys and the alarm screams when the battery is connected.
The car wont start and there's an orange light in the start button.
What is the hell is wrong with my car?
Old 03-13-10, 05:26 AM
lex
lex's Avatar
have you called the dealer?
Old 03-13-10, 06:05 AM
Tomasu
Tomasu's Avatar
No, because it's Saturday. I'm going to give them a call on Monday. I think this could be something big... I think I saw the yellow engine icon being lit as well.
Nothing wrong with the car before the battery died.
Very strange.
Old 03-13-10, 07:30 AM
EJC
EJC's Avatar
Very strange.
a 45slug through the computer should end the misery quickly
seriously though, I would guess you probably have to do some sort of system reset. Call the 800 lexus emergency # in the manual they should be able to tell you how to restet the system
Old 03-13-10, 07:33 AM
RX469
RX469's Avatar
i'm curious about this as well.
Old 03-13-10, 08:49 AM
ecr527
ecr527's Avatar
Did you check the owner's manual? I'm sure it'll mention something about this.
This would also happen to me on my old Acura everytime I would disconnect the battery. I always needed to have the key fob handy to disarm the system. I don't know if it's the same on the Lexus, but it's worth a try...
Old 03-13-10, 11:37 AM
wolverine
wolverine's Avatar
have you tried pressing unlock on your key fob?
Old 03-13-10, 01:24 PM
Noz
Noz's Avatar
This happened to me once too when my battery died. I had to disconnect my batter since the alarm kept on stuttering. When I would reconnect the battery, same thing would happen. I ended up using an old school frustration method of "keep on pushing the start button fast" and it worked. The car eventually recognized the key fob and started acting normally.
GL
Noz
Old 03-13-10, 10:56 PM
KuyaPatz
KuyaPatz's Avatar
GL
Noz
I am def going to keep this in mind if this happens to me hahaha. if that doesn't work Ill use a sledge hammer on the button instead.
Old 03-13-10, 11:59 PM
blk250
blk250's Avatar
to the OP try Noz method...(good to know)
Old 03-14-10, 10:45 AM
Tomasu
Tomasu's Avatar
Okay, I tried that and it actually recognised the key but it still didn't start. There was a text on the navi screen saying "Check the system" or something like that. The noise was horrible so I was forced to disconnect the battery.
I'll call the dealer tomorrow. Maybe the ECU needs to be reset or something...
Old 03-14-10, 01:57 PM
DailyDrive
DailyDrive's Avatar
hey op,
did you make sure you didn't have the terminals backward... i'm just saying cause my friend did that to his s2000 and it did the same thing as far as the alarm going off and lights flashing and he blew some fuses.. it happens. gl and keep us posted
Old 03-14-10, 02:32 PM
Noz
Noz's Avatar
Did you jump start your car? The car won't start by its self since the battery is dead. After I got the car to recognize the key, I jumped the car and let the alt recharge the battery and everything worked fine.
GL
Noz
Old 03-16-10, 12:31 AM
Tomasu
Tomasu's Avatar
A small update and a question..
The car will go back to the dealer tomorrow.
Does the car have a steering lock? I need to turn the wheels to get it on a trailer, but if there's a steering lock that wont be possible.
Old 03-16-10, 04:44 AM
Bichon
Super Moderator
Bichon's Avatar
Yes, the car has a steering lock. (If you listen, you can actually hear it locking when the first person opens a door after shutting off the car, and hear it unlocking during the startup sequence)
Quick Reply: Removed the battery - alarm screaming. Quick help needed!
