Want The Is-f Needles Look, How Do I Take Off The Cluster?
Old 03-17-10, 08:44 PM
2slow
2slow's Avatar
Hey Javy, Is there even a Oil temp sensor in the 2IS? What i looked at was the oil temp sensor assembly in the is-f. It seems like it mounted near one of the belts.
I wonder if that part is bolt on to the 2IS.
Old 03-17-10, 10:28 PM
javyLSU
2IS OG
javyLSU's Avatar
There is an oil temp sensor in the ISx50, there's just no lead to the instrument cluster.
Javier
Old 03-18-10, 02:38 AM
Ki11switch
Ki11switch's Avatar
JavyLSU What exactly has to be adjusted? and can this adjustment be done as a DIY?
Old 03-18-10, 05:47 AM
javyLSU
2IS OG
javyLSU's Avatar
What has to be adjusted for what??
Javier
Old 03-18-10, 11:03 AM
AtlantaGuy
AtlantaGuy's Avatar
Can someone post on how to remove the trim ring around the gauge bezel. Particularly the lower portion of it, how to remove the pice below the steering wheel, and then gain access to the bezel.
Old 03-18-10, 02:29 PM
integlspwr
integlspwr's Avatar
where is the DIY for the is-F cluster?
Old 03-18-10, 02:43 PM
GiantsFan
GiantsFan's Avatar
Javier
I think he's referring to your other thread where you were talking about adjusting the speedo / odo ...
Old 03-18-10, 06:08 PM
Initial_K
Initial_K's Avatar
Can't you put a clear blue overlay on the needle?
Old 03-19-10, 01:57 AM
2slow
2slow's Avatar
Javier
Can we probe into the lead from the oil temp sensor to the PCM?
Old 03-19-10, 07:21 AM
javyLSU
2IS OG
javyLSU's Avatar
I'm sure there's a way to do it Tim (and what you mentioned seems to make sense), I just haven't had the time to think it through at all. It's on my "to-do list", because this was one of the biggest reasons I wanted the IS-F instrument panel.
Javier
Old 03-19-10, 11:51 AM
2slow
2slow's Avatar
I have the F gauge on the way, so when it come in, i'll start looking at some wiring diagrams..
Old 03-19-10, 12:55 PM
Kurtz
Kurtz's Avatar
Dare I ask what Lexus gets for an F dash cluster?
Old 03-19-10, 01:20 PM
javyLSU
2IS OG
javyLSU's Avatar
^MSRP is $1500, you can order one online for ~$1000.
Javier
Old 03-19-10, 02:57 PM
Kurtz
Kurtz's Avatar
Javier
Yeah, figured it'd be something crazy like that... I suspect if I asked the MSRP on those free cookies in the waiting area it'd be $349.95 each.
Old 08-19-10, 02:40 PM
tru350z
tru350z's Avatar
Javier
Do you have to program it to make it work? Or simple plug and play? Did you buy new or used? How about gear display? 6sp Auto to 8sp Auto?
Do you have to adjust speedo?
Thanks in advice!
Quick Reply: Want The Is-f Needles Look, How Do I Take Off The Cluster?
