Want The Is-f Needles Look, How Do I Take Off The Cluster?
#33
#34
#35
to take off the cluster, u first take the 2 screws on the top, then u remove the trim below the start button (it has the traction button on)..do the same for the other side (it helps if the doors open)...then there should be a screw on each side behind the trim, use a flashlight to find them and use a long philips, just make sure u dont drop the screw..when the bezel is removed, u wiggle the cluster out..there should be a clip on the top so use ur fingers to unclip it...once u get it out, make sure ur steering wheel is all the way down and out..then unplug and slide the panel face down out the side facing the door (make sure the doors open)
#36
#37
#41
and if u wana change the color of the needle, take a sharpie, color it in, and then some nail polish remover and wipe it..the nail polish remover cant remove all of the ink so ur left with a very thin coat that equal and noticeable...getto/cheap/it works
#42
I ******ed up my cluster for open it up. Right now the needle is stay below zero and I have to add 25mph to whatever on the reading so I hope you think twice before you start messing with it!
#44
to open it i think u need to remove the clips on the side and to remove the silver trim u need to unscrew the back if i rememeber correctly...i decided to spay paint the silver trim flat back and it looks pretty good
