Will those wheels fit? START HERE.
Old 10-20-10, 03:16 AM
  #1651
Mv350
Mv350's Avatar
tony in the 818 around 80 bucks for everything
Old 10-20-10, 03:17 AM
  #1652
JohnyDrama
JohnyDrama's Avatar
Hi guys,
Just wanted to provide an update:
Front: 19x8.5 - 45 offset - 235/35/19 - Kuhmo KU31
Rear: 19x9.5 Rear - 45 offset - 265/30/19 - Kuhmo KU31
The above setup works fine, no scrubbing.
Happy motoring!
Old 10-20-10, 07:49 AM
  #1653
ATX_250
ATX_250's Avatar
Originally Posted by ATX_250
What will I need for these to fit
Wheel specs:
19x9.5+42
19x11+38
Can someone help me please,and what size tires would you guys recommend?
Old 10-21-10, 01:10 AM
  #1654
Mv350
Mv350's Avatar
you should be good with that. run 235/30 and 275/30 in the rear.
Old 10-21-10, 01:12 AM
  #1655
tnogi
tnogi's Avatar
Nice, I think I have his number can you please
PM it to me aswell just in case? thnx again
toHn
Old 10-21-10, 02:39 AM
  #1656
Mv350
Mv350's Avatar
i dont have it, check the socal section.
Old 10-21-10, 07:34 AM
  #1657
MashinA
MashinA's Avatar
Mv350 u never answered my question
here it is lets see if i can word it right: i am currently running on work vsxx 20x9, 225/35 +36 front and 20x10 255/35 +32 rear. Im dropped on bcrs. i currently only have minor rub in the front on the tab and bolt that hold the bumper to the fender after i did some mods to it. my fenders are pulled and rolled/shaved?. i am tucking a lil bit but i want to get a fuller flusher look so to speak, so i was wondering if i went a little wider on the tires 235/35 and 275/35 front and rear respectively, will that fill it out some(make it stick out a little more if you will) or will i need to use spacers? or will it just rub way too much?
Old 10-21-10, 07:55 AM
  #1658
MiiK350
MiiK350's Avatar
You guys think it'd be a bad idea going 285 on a 19'' x 10'' + 38 ? I drag a lot and have some serious contenders to race before the year is up so I'm going to need the traction.
Old 10-21-10, 04:23 PM
  #1659
Mv350
Mv350's Avatar
run spacer. 10mm front and 15mm rear. and you should be good. just mod your fenders accordingly.
if your dragging your car and want traction your running the wrong size wheel. go to a 18" or 17". then run a 40 series or 50 series. and then youll gain traction.
Old 10-21-10, 06:42 PM
  #1660
steezy
steezy's Avatar
Im still wondering what to do with the tab... Lol
Old 10-21-10, 10:03 PM
  #1661
Mv350
Mv350's Avatar
i cut mine compltely off.
when hammered before.
after when cut off. and black brcket cut back
Old 10-21-10, 10:16 PM
  #1662
JoshIS408
- - G T V I P - -
JoshIS408's Avatar
^ if you cut it off completly, how does it hold the bumper now? Need tof ix mine, i shaved it but its cutting into my tire
Old 10-21-10, 11:56 PM
  #1663
Mv350
Mv350's Avatar
when you put the black molding on it holds the bumper
Old 10-22-10, 12:00 AM
  #1664
MiiK350
MiiK350's Avatar
18''x8.5+25; 255/40 on H&R's?
Basically stock wheels with 25mm spacer, or should i juust go 20mm to be safer?
Old 10-22-10, 04:30 AM
  #1665
Mv350
Mv350's Avatar
youll be good with either
Quick Reply: Will those wheels fit? START HERE.
