Will those wheels fit? START HERE.
Old 01-20-11, 12:50 PM
  #1846
ATX_250
ATX_250's Avatar
Originally Posted by ATX_250
Need help with these, I just purchased 225/35/19 for the front Im hoping I can make it happen, just wondering if a camber kit is necessary for this set up??And would 245/35 be okay for the rears???
19X9.5+25 19X10.5+18
Old 01-24-11, 04:39 PM
  #1847
speedywa
speedywa's Avatar
i have a set of tires 235/35R19 that are from my friend 235/35R19
i wonder if i can run 19x9 +35 front and 19x9 +25 rear
any fender modding needed? will it look odd? i'm now lowered on f sport and probably get tein coilover later in the future.
Old 02-01-11, 10:12 AM
  #1848
Focker
Focker's Avatar
18x8.5 F +45
18x9.5 R +50
2007 IS350
225/40 front, 255/40 rear.
Will it fit? I used the 1010 calculator and it says 6mm closer in the front (inboard) and 13mm inboard on the rear.
Old 02-02-11, 12:12 AM
  #1849
Mv350
Mv350's Avatar
thatll fit no mods.
Old 02-03-11, 08:54 AM
  #1850
pli
pli's Avatar
picking up wheels this weekend.
Front
19x8.5 wheels +42
245/35/R19 tires
Rear
19x9.5wheels +42
275/30/R19 tires
will these fit?
Old 02-03-11, 03:43 PM
  #1851
santacruz
santacruz's Avatar
Ok so I've found a killer deal on a set of wheels I like for my IS350 but I have to decide which offsets to go with. They are 19x9 and 19x10 available in +25,+35, and +45 offsets. My car is lowered on tein s-techs. Which offsets would be a good compromise between form and function? I don't want to have to cut or roll my fenders if at all possible.
Old 02-03-11, 09:00 PM
  #1852
pli
pli's Avatar
+35 is ideal with a proper tire for function and form. +25, youll have to stretch and may have to do some fender work depending on tire. +45 is a high.
Old 02-04-11, 12:43 AM
  #1853
Vip.Status
Vip.Status's Avatar
found a deal on work t1's
its 19x8.5 offset +38 F / 19x9.5 offset +42 R
will it be a good fit?
thanks and im on bcr coilovers
Old 02-04-11, 02:30 AM
  #1854
Mv350
Mv350's Avatar
Front
19x8.5 wheels +42
245/35/R19 tires
Rear
19x9.5wheels +42
275/30/R19 tires
will these fit?
you will be good. +42 is nothing to worry about. i would go to a smaller front tire tho. something like 225/35 or 235/35
+35 all around 215/35 front 235/35 or 245/35 back
itll fit no prob
Old 02-04-11, 03:28 AM
  #1855
Vip.Status
Vip.Status's Avatar
thanks mv350
Old 02-05-11, 07:38 AM
  #1856
cholmes1
cholmes1's Avatar
I searched the thread and could not find anyone who has asked about the 19" OEM RX8 wheel.
Would those fit an IS350? I have seen the Genesis Track wheels and thought they looked sharp, but I like the RX8's a little more aesthetically.
Looking at these in particular: http://images.thecarconnection.com/l...00189757_l.jpg
Of course I would change the center cap.
Thoughts...
Old 02-07-11, 12:10 PM
  #1857
Vroomin350
Vroomin350's Avatar
sup guys, I see most people talking about +31 is the craziest u could go out back on the 2IS with out fender mods..
however this is what I got in mind..
18/8.5 +30
18/10 +25
Tires are
235/40/18
255/40/18
Will I have rubbing issues. if yes where ? front ? back ? I plan on lowering on Coils, prob megan...
Will I have to roll fenders for the +25 in the rear? thanks
Old 02-10-11, 03:28 PM
  #1858
redline201
redline201's Avatar
is there any way i can fit a 19x8.5 +22 with a 235/35/19 tire without rubbing like crazy?
Im on bcr coils so i can adjust ride height but i dont wanna look like 4x4 and i really dont want the tires to stick out like crazy.
can i roll the front fenders at all? will that give me any clearance? are there any 235/35/19 tires that run a little on the small side compared to the general UHPs?
what if i mill 3mm off the wheels?
Old 02-10-11, 07:00 PM
  #1859
IS25Heaven
IS25Heaven's Avatar
i run a 19x8.5+22 on a 225/35/19 i wish i had gone with a 215/35/19.
you wont rub when you are going straight, but its gonna be a different story when you turn and when you hit pot holes. I would try to go with a 215.
Old 02-10-11, 07:30 PM
  #1860
projectdna
projectdna's Avatar
if you're looking to run the combination of 235/35-19 and 19 x 8.5 +22 in the front, you're going to rub.
you can roll the fenders, but you will rub at the tab where the fender meets the bumper.
milling the inside mounting face to effectively increase offset (by pushing the inside mounting face farther away from the centerline of the wheel) weakens its structural integrity, and if you have closed-end lugnuts you might end up having too many threads on the studs to mount before the lugnuts can secure the wheel.
Quick Reply: Will those wheels fit? START HERE.
