Will those wheels fit? START HERE.
#1862
hello, i would like to run 18by10 in the rear with a 35 offset, and use my stock 255 tires, will there be any rubbing or tire stretching issues or will it fit no problems or should I get a 275/35 priofile tire
#1863
Seller says they will fit if i roll/pull fenders, but I'm VERY skeptical. Never seen lips that size on a 2IS.
WILL THESE FIT?? (I can swap tires if needed, more worried about the rims).
19x8.5 -6
Mid disk
4.25" lip
215/35/19 Falken ST-115 (Bubbled, SHOT DONE DEAL)
19x9.5 -6
Mid disk
4.5" lip
225/35/19 Toyo Proxy 4 (Camber worn 1000 miles)
Thanks for any input!!!
19x8.5 -6
Mid disk
4.25" lip
19x9.5 -6
Mid disk
4.5" lip
#1865
I have Work S1 Meister 3PC that I had on my G35 Coupe.
F: 19 x 9.5 +24 in BFG KDW2 245/35/19
R: 19 x 10.5 +23 in Toyo T1-R 275/35/19
I know I'm gonna need new tires. What sizes do you recommend?
#1867
i know this has been aked 100 times by now but i couldnt find it
looking to do a spacer on my g-spider rims nothing crazy just looking to be flush not hellaflush lol
what size do i need front and back??
thanks guys
thanks guys
#1868
With a 20x10 and a 40 offset on an AWD that is not lowered for the rear wheel. What size tire should I get to not have to many rubbing issues? Is it possible to still go 35 series tires in the back I was thinking 245/35/20?
#1869
for the rear 245/35/19 could do it and shave your rear fenders
#1870
#1871
245/35/20 is a stretch and it all depends on what size you have in the front
#1872
I will be running front 20x8.5 with a 38 offset and rear 20x10 with a 40 offset. Front tires are 225/35/20 which I know works cause I have them now but the rear I have no idea what size tire to run?? Can I still get away with a 35 series thickness in the back ?
#1873
Anyone have any knowledge on these?
I searched the thread and could not find anyone who has asked about the 19" OEM RX8 Track wheel.
Would those fit an IS350? I have seen the Genesis Track wheels and thought they looked sharp, but I like the RX8's a little more aesthetically.
Looking at these in particular: http://images.thecarconnection.com/l...00189757_l.jpg
Of course I would change the center cap.
Thoughts...
Thoughts...
#1875
Here's one for the Gurus
Front: 18x9.5 +40 / +27 235/40/18
Rear: 18x10.5 +30 265/40/18
Any info on this setup, as far as rubbing, no rubbing, or if it works, will be greatly appreciated.
Note: This is on F-Sport 1Gen spring drop.
