Will those wheels fit? START HERE.
Old 02-25-11, 08:24 PM
  #1876
Sffd103
Fire Slayer
Sffd103's Avatar
Originally Posted by kvl
hi guys
i have one stupid qu
will 19" front 8" with 38 offset and rear 9" with 42 offset fit rwd is250?
thanks
That will fit no problem.
Old 02-27-11, 04:45 AM
  #1877
kvl
kvl's Avatar
thanks Sffd103
Old 02-28-11, 12:48 AM
  #1878
Mrbanhbao
Mrbanhbao's Avatar
hey guys,
i might pick up the Algernon Intelessee II for my gf
she has a 10' is250 AWD. I was thinking:
front- 18x8 +36
rear- 18x9 +36
What do you think? and whats a good tire size for her? she might give her
car a minor drop, nothing too low (springs). =D Any help will be appreciated. Thanks
Old 03-01-11, 09:48 PM
  #1879
agarciagmu
agarciagmu's Avatar
Will these fit on my 2006 IS250AWD:
Off Set: +40mm
Bolt Pattern: 5x114.3
Center Bore: 73.1mm
And will I have to worry about any rub when I put F-spring springs & shocks?
Old 03-02-11, 02:21 PM
  #1880
twenty
twenty's Avatar
SSR Vienna
19x9+11
19x9.5+18
Will these fit a '07 RWD IS250?
Old 03-02-11, 05:29 PM
  #1881
IS-SV
IS-SV's Avatar
Off Set: +40mm
Center Bore: 73.1mm
I don't see tire sizes. And rubbing won't be a result of the F-springs & shocks, more the effect of wheel width, offsets and tire sizing.
Old 03-02-11, 08:10 PM
  #1882
pratik_10
pratik_10's Avatar
hey guys i have a friend that has some volk lmgt4 nismos that he will sell me super cheap they are
19x8.5 fronts.// 19x9.5 rears.
+30 and +25 offset
will they fit on my car (is350) without rubbing
these are the tires on the rims
245 35 19 and rears are 275 35 19
nitto NeoGEn
Old 03-06-11, 02:59 PM
  #1883
CarbonDtls
CarbonDtls's Avatar
OK looking to get a set of 18s in these possible sizes for my rwd. I will be dropped on BCR coilovers and would like to be pretty low, no finger gap but no lower than that and I do not want to roll or do anything to my fenders.
For the fronts its gonna be
18x8 but possible offsets are either 48 or 35
Tires I would like to go either 225/35/18 or 235/35/18
Rear will be 18x9
Offset will be 38
Tires was looking into 265/35/18
I'm not trying to be aggressive but I don't want the factory high offset look
Any advice on offset and tire sizes would be helpful
Rich
Old 03-09-11, 09:09 PM
  #1884
600rr05
600rr05's Avatar
what about 19x8.5 & 19x10 +37 all around ? and what size tire would be best ? i have rear tires from my old wheels which were 265/30 need to replace fronts so looking for some idea's.....
Old 03-09-11, 10:08 PM
  #1885
Focker
Focker's Avatar
Originally Posted by Mv350
Snip
No mods needed up to these offsets
front
18 & 19x8.5+25 225/40(35 for 19's) can go more aggressive with a smaller tire
rear
18x9.5+27 235/40
19x9.5+30 235/35
OK, I've tried searching through this thread as best I can and used the 1010 tires calculator, but want to be sure before I order the wheels.
I plan on going with Foose speed wheels (really like the machined look). 18x8 up front and 18x9.5 in the rear. IS350 lowered on F-sport springs.
I will be running stock tire size 225/40/18 front and 255/40/18 rear.
The lowest offset they have for the front is a 40 (OEM is 45) so that is what I am going with there. My question is in the rear. 1010tires suggests with a 18x9.5 to go with a +37 offset, the problem is the rears only come in +40 or +35.
So, do I go +35 or +40 in the rear? I don't want any rubbing or other junk. Will the +35 rub? Will the +40 look to sunken in relative to the front?
Old 03-11-11, 11:48 AM
  #1886
niccuhles
niccuhles's Avatar
Im trying to fit 18x10 +25 215/40/18 Falken 452 on a IS350(bigger brakes). Will they fit with the fenders rolled?! Thanks in advance!
Old 03-11-11, 11:58 AM
  #1887
niccuhles
niccuhles's Avatar
Old 03-11-11, 12:53 PM
  #1888
2FNQUIK
2FNQUIK's Avatar
OK guys, this thread is designed for you to GO THROUGH and READ to help determine what will and will not work on these cars...its not the magic 8 ball shake it and get an answer thread, best thing you can do to determine what will fit your car safely is to remove either your front or rear wheel and take measurements from the mounting pad to nearest obstuction on the front of the wheel (fender) and rear of the wheel (spring/shock/spindle..) to determine backspacing and clearance...lastly you can search the forum for members that have a setup that you like or close to what you're looking for and have them give you their specs if they're willing...just trying to help you guys who post questions "will this/that fit" and you don't get a response....
Old 03-11-11, 12:57 PM
  #1889
projectdna
projectdna's Avatar
^ our 2is fitment guru has been MIA for a while.
his so-called/self-proclaimed replacement... well, he's MIA too.
however, helpful advice nonetheless. it's a gem mine of information in here, and people should search through this thread to find what they're looking for.
Old 03-11-11, 06:16 PM
  #1890
Focker
Focker's Avatar
What's the point of the thread then? I've searched through this thread, and pretty much all through the 2IS sub forums and I'm just looking for an opinion on what may look/work better. I think I've done a lot more searching than most people in this thread have. I figured out the recommended backspacing for the 18x9.5, but it is conveniently right in the middle of my 2 options. Why wouldn't I post up a question? Should the thread just be "Hey I bought some wheels, they fit. This is what I have..."
Quick Reply: Will those wheels fit? START HERE.
