Will those wheels fit? START HERE.
#1967
I'm a super noob, so help me out fellas.
Will this set up work my ride? The car is completely stock.
Front tires: 225/40/18
Rear Tires: 255/40/18
Front wheel: 18x8, 40MM offset
Rear wheel: 18x9.5, 40MM offset
I have toyo proxes t1r tires, and based on toyo website, it says that 255/40/18 size tires are approved for rim width 8.5-9.0-10.0.
with that in mind i'm also wondering, when they said 8.5-9.0-10.0........
does that mean ONLY 8.5, 9.0, and 10.0? Or anything between 8.5-9.0 and 9.0-10.0?
sort of confusing to me, so please tell me what you all think.
THANKS A LOT!!!!!!!!
#1968
#1969
18x8 +38 offset ssr comps. 18x9 +44 in the rear. Planning to run 265/35/18 and 235/40/18. What would be the best size for comfort yet at times grippy. Keep in mind car is lowered on eibach pro. And rolling is possible. I have access to one. I just want comfort up front and no rubbing. Its my girlfriends ride. So a size chick friendly. However she's a crazy driuver.
Can a Brotha get some help with the tires sizes? Please?
#1970
run your stock size front tire. and you could even run stock rear tires. i suggest 225/40 and 255/40 but on eibach's you wont really be low enough to rub tire so youll be fine.
not to cause any ruffling of feathers but ive beat this horse to death.
18x8.5+27 18x9.5+28 will fit no problem with a very very mild stretch on stock fenders. 225/40 and 245/40 will be what most every one is looking for when they do not want to mod their fenders.
this is 18x8.5+27 225/40 18x9.5+30 245/40 just so you can see what its like
![Name: 101_1995.jpg
Size: 191.0 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/460144d1501791993-will-those-wheels-fit-start-here-101_1995.jpg)
![Name: 101_1997.jpg
Size: 155.4 KB](https://www.clublexus.com/forums/attachments/is-2nd-gen-2006-2013/460145d1501791993-will-those-wheels-fit-start-here-101_1997.jpg)
#1971
What offsets would it be possible to run on a 20x9F and 20x10R with minimal body work. I may be able to roll the fenders but no pull action. I want them to be aggressive but I know it's not going to be lower than a 3X. I have done my research but I want an expertise opinion. And would it be possible to run a 20x10.5 in the rear as well? Thanks in advance..
#1972
#1974
20x10+20 245/30
20x10.5+30 265/30
you said with out a pull correct?
#1977
Just bought wheels in these exact same sizes and offsets. They are due to arrive tomorrow, I'll post pics for you.
#1978
#1979
This setup was 19x8.5/9.5+15 tucking almost all of the tire
![](https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc4/34481_1370266970495_1046340158_30877812_7599727_n.jpg)
![](https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash2/37280_1381087921012_1046340158_30900354_2574293_n.jpg)
