Will those wheels fit? START HERE.
#2011
if your fenders are rolled and fender tabs are shaved, then no.
the +37 offset would likely work without fender mods.
but if your uncomfortable with fender mods, go with more conservative wheel specs.
varrstoen is right down the street from where i work, and iirc HKS350 has a set of varrstoens (TE replicas). they're fine AFAIK.
your posted specs will fit (heck, anything can fit with $$$$), but you'll need fender work all around (roll + shaved fender tabs).
i think a few that are running those spec wheels are running 235/35-19 and 255/35-19.
I'm wondering if these Varrstoen wheels will fit..
They're 19x9.5 +22 and 19x10.5 + 22
I think they also make them in +30 but +22 would be a kick *** dish. I'm sure Id have to stretch tires but no idea what size to go with. I'm going to be lowered on Megan Racing EZ streets. Don't really want to have to roll the fenders but I will a little bit.
Anyone ever use the varrstoen wheels??
#2012
My last setup was 19" 8.5/9.5 +22 on 225/35;255/35. For this setup I rolled the fronts, & for the rear, I rolled, pulled and shaved the rear. I want to move up to a 19"9.5/10.5 with the same tires. Will I rub?
#2014
p.s.
IF YOU AIN'T RUBBIN', YOU AIN'T DOIN IT RIGHT!
proof is in the puddin!
Get your tires buzz on friends
#2015
Question about some rims for sale.. what does this mean?
"20x9 +32 offset and 20x11 +60 offset"
I don't understand the +60 offset.. ? Looks great in the picture, but a little confused..
Sorry if thats a nub question
Thanks
Thanks
#2017
Okay so im a noob and dont understand this fancy + what ever amount stuff lol
but i was looking at some rims and as far as i know the offset i can get is 18x8 and 18x9 would that work??? what would the rest of the offset need to be??? I have a 09 is250
#2018
it's nothing "fancy".
"offset" refers to the distance between the centerline of the wheel and the inside mounting face. the lower the offset, the closer the inside mounting face is to the centerline, which pushes the wheel out farther away from the car. the higher the offset, the farther the inside mounting face is from the centerline, pushing the wheel in farther towards the car.
the diameter and width will typically determines tire size. offsets will also play a factor in determining tire size, as well as whether you will need fender work or not.
#2022
thinking about buying some tsw carthage for my sc300. 18x8 front and 19x9.5 for the rear. 20 offset on all 4. will i need to roll fenders or stretch tires? how flush will it be.
http://www.wheelwarehouse.com/p-5042...ge-silver.aspx
#2023
#2024
[QUOTE=Mv350;6306652]you should be good with that, run a 265/30 in the back and either 225/35 or 235/35 up front
So it should sit flush with the fender with this setup? not passed the fender?
#2025
Hey Guys, have a chance to get a good deal on some Volks in 18's. Will I have any issues clearing the Front brakes? I know the wheels aren't staggered but a good deal is hard to pass up. Any suggestions appreciated
IS350 on FSport Springs
18x9 +30mm Front
18x9 +30mm Rear
18x9 +30mm Front
18x9 +30mm Rear
