Will those wheels fit? START HERE.
#2044
I'll mostly be wanting to clear the rear brake caliper and suspension components and have it stick out just a lil bit.. I just bought ichiba v2 15mm spacers and will take pics with wheels installed before and after spacers to see if it clears..
#2045
btw, keep an eye out for suspension clearance issues in the rear w/ that size and offset. just a heads-up.
answer those two first.
you should clear suspension components and the brake calipers in the rear (backspacing is appx. > 0.5" compared to oem rear 18's).
i have doubts whether you can pull off a 275/30-19 without a roll and a pull. unless you're feeling real adventurous with fender work, i'd err on the side of safety and go with narrower tires (265 or 255)
#2047
Coo thanks man.. I was planning on doing a roll and slight pull on the rear.. hope it'll tuck in just fine.. if not I'll raise it up a bit until I get new rear tires... or run a lil neg camber hopefully enough where it wont rub in the inside.
#2054
Will 225/35/19 be a stretch on a 19x8.5 38 offset for the front? I was gonna do 235/35 but worried about rubbing and don't want to do any fender mods.
#2055
plan for fender work, and keep the oem 18" tire sizes (225/40-18, 255/40-18).
i run 215/35-19 and 245/35-19 on rolled fenders and shaved fender tabs, and i still have the occasional rubbing.
though if you didn't want to do any fender mods, you should've considered more conservative offsets.
