Will those wheels fit? START HERE.
Old 05-03-11, 04:41 PM
  #2056
kvl
kvl's Avatar
thanks for you reply projectdna!
hmm... would you have any ideal if 19x 8.5 offset 35(f)/9。5 offset30(r) fit? i hoppe they do as i just order them
Old 05-03-11, 04:56 PM
  #2057
projectdna
projectdna's Avatar
if you already ordered them, what do you need to know?
Old 05-03-11, 06:13 PM
  #2058
Vip.Status
Vip.Status's Avatar
19x8.5 +18 215/35 for the fronts
can? no can?
thanks
Old 05-03-11, 08:45 PM
  #2059
projectdna
projectdna's Avatar
can? no can?
thanks
modified fenders + shaved fender tabs.
Old 05-03-11, 08:57 PM
  #2060
Vip.Status
Vip.Status's Avatar
^^ cant i just melt my fender liners in a little??
Old 05-03-11, 09:41 PM
  #2061
projectdna
projectdna's Avatar
before i answer that question, let me ask you this:
currently, where is your front ride height (approximately)?
when you can answer that question, i will answer your question.
Old 05-03-11, 11:52 PM
  #2062
Vip.Status
Vip.Status's Avatar
im not really slammed, pretty just no gap from the fender to the wheel
Old 05-04-11, 12:30 AM
  #2063
projectdna
projectdna's Avatar
at that height?
don't bother heating up your fender liner; it'll be a waste of time for you.
again, fender modifications + shaved fender tabs.
that, or run wheels with more conservative offsets, if you don't have the heart for fender modifications.
Old 05-04-11, 04:19 AM
  #2064
kanklez
kanklez's Avatar
hey guys what about this setup with a mild drop?
20x9 +32
20x10.5 +42
Old 05-04-11, 10:01 AM
  #2065
projectdna
projectdna's Avatar
20x9 +32
20x10.5 +42
depending on how you define "mild drop".
you shouldn't need fender work in the front, depending on your tire size.
you'll need work fender work in the rear.
Old 05-04-11, 01:36 PM
  #2066
Stevoe88
Stevoe88's Avatar
Im planning to get some varrstoen's and debating on what set up I want to get. I'm gonna be pretty low with no camber kit so I wont be able to run much camber to make low offset wheels fit. I will be flaring out my fenders and rolling them quite a bit to compensate though. I was thinking about (Front)19x9.5 +30 and (Rear)19x10.5 +22 with a little stretch. What do you guys think? I want to be flush with no poke. I'm gonna try to touch the fender with the rim on coilovers.
Old 05-04-11, 01:39 PM
  #2067
MIA_LEX
MIA_LEX's Avatar
Get +22 up front also
Old 05-04-11, 03:03 PM
  #2068
Stevoe88
Stevoe88's Avatar
Do you think that will fit in the front without messing up the fenders? I don't want to rub at all in the front. I will be flaring the fronts out pretty far out though.
Old 05-05-11, 08:25 PM
  #2069
CarbonDtls
CarbonDtls's Avatar
Need a quick answer since gonna order tires in the morning.
Is 225/35/19 a stretch on a 19x8.5 wheel? I really want 235/35/19 but pretty sure I will rub in front, offset being 38.
I hate the stretch look.
Old 05-05-11, 09:04 PM
  #2070
SB350
SB350's Avatar
I'm running a 225/35/19 on a 19x9 +38 up front. It's a mild stretch for a 9" wide wheel so it will be an even less stretch on an 8.5. I had quite a bit of rubbing up front with the 225/35 when I lowered on coils, but I have no rubbing now after minor fender mods.
Quick Reply: Will those wheels fit? START HERE.
