Will those wheels fit? START HERE.
#2103
I thought this would be the second best place to ask. I was trying on the Vossen 078 from a friend who had a G35
front's are 20x9 (+25 offset)
rear's are 20x10.5 (+30 offset)
When I installed the front wheel with the McGard lug nut on my stock IS250, the wheel was still a little wobbly even with nuts tightened.
Anyone had this issue?
And what tires to recommend, if drop 1-2 inches.
Thanks
Thanks
#2105
#2108
#2109
I was going to buy 225/35/19 and 265/30/19 for my car but someone on my.is told me I should run 265/35/19 in the rear. What do you guys think about that? Lowered on F-sport springs/shocks.
#2111
what it the realistic measurement difference between a 225 and a 235 upfront? I cant see it being so drastic that a minor heat gunning of the liner wont fix the difference unless its huge
#2112
I'm not sure but everyone tells me ill rub with a 235 and not with a 225 on a 19x8.5 with +35.
#2113
as such, when i say "thinner" tire, i don't mean a tire w/ thinner sidewall, but a tire w/ narrower treadwidth.
i'd recommend running 225/35-19 up front and 255/35-19 in the rear.
if you don't have your fenders modified to accomodate higher-treadwidth tires, it will matter.
