Will those wheels fit? START HERE.
#2373
you do not need extended studs - those are usually for slide-on spacers (i.e. ichiba type I's).
on a related note, you do need aftermarket lug nuts. your oem lug nuts will not fit because they are too large and/or shallow.
#2377
I've been running staggered now for about a year without problem with fitament, my main problem is that Im burning thru tires!!! I'm currently looking at a new set, so my quetion is what is the optimal offset for 19x9 or 19x8 at all 4 corners for AWD setup. I do not want to modify my fenders, if I HAVE to just rolled.
#2379
btw if you looking for a nice unstaggered set of 18's check out the outlet on work wheels website
quoted because its what is needed
#2380
i'd post pics of what 215/35 + 245/35 looks like on a 8.5"/9.5"-wide set-up, but my wheels are dirty. :/
#2381
255 might rub, 245 gives you a stretch thats needed, which is why project suggested a 245/35 because its not a crazy stretch and something he would even drive. i was gunna suggest a 235/35 until i read this. run that tire setup suggested and you will be ok. its not like your stretching a 225/40 over an 18x10.5 like i have, not thats when the tires arent super safe to drive on.
225/35 for the 8's 235/35 for the 9's
19x8.0
19x.8.5
19.9.0
each at all 4 corners.
#2384
Hey, I searched this thread, and the AWD thread, and never seemed to find my answer. I was hoping to run
18x9.0 offset +25mm (2.75" lip)
18x10.5 offset +20mm (4.25" lip)
And was wondering if it would be to aggressive (rubbing issues). Would i have to do fender mods.
Thanks
Thanks
#2385
Thanks
Thanks
