Will those wheels fit? START HERE.
#2476
19x8.5 +35 Front
19x9.5 +33 Rear
225/35-19 Front
265/30-19 Rear + Rolled fenders.
Rear is dropped til no finger gap and front probably has a little more than 2 credit cards gap. Will I rub? :P
19x9.5 +33 Rear
225/35-19 Front
#2477
Hi sorry to ask again. The rims that i am going to buy is the Enkei Ammodo.
So i know that 18x8 +40 will fit fine. Should i go for the 19x8 +48 offset instead? Would this look nicer? or should i stick with the 18x8 +40? (It was the only 19inch size they have).
Thank you for your help!
as i've posted before, the offsets for 18x8 is close if not exactly the same as OEM 18's (+40).
19x8 +48 will be so far in that it would "look" worse than 18x8 +40. that, and i question if 19x8 +40 clears your brake calipers.
265/30-19 wouldn't be my first choice w/ your rear wheel specs, but i don't see how that tire size would cause clearance issues.
#2478
aesthetically, neither look "nice".
you should be fine.
you should be fine.
#2481
false.
sidewall height = treadwidth x ( aspect ratio / 100)
so for 235/30-20, sidewall height would be 70.5 mm.
and for 245/30-20, sidewall height would be 73.5 mm.
however, note that actual treadwidth and sidewall height will slightly differ between manufacturers despite being spec'd at the same size.
#2482
My wheels are 19 x 8.5 +34 front and 19 x 9.5 +35 rear. I'm planning to run 235/35/19 up front and 265/30/19 in the rear. Right now my car is at a moderate drop, just 2 finger gap all around, but might lower to a finger gap later on. Since I use my car as a daily driver, do you think this is a good setup? Any fender mods required?
#2484
Rims
Okay I think i am going to take the risk and go for the 18x8+40. But now i have been told I should drop the car. I am looking at the Eibach Pro Kit which drops 1 inch in the front and 0.8 in the rear. This should be fine and it should not rub?
#2485
you're welcome.
#2487
that will fit with rolling your fenders all around. itll be a tad tight up front, but the rear should fit like a 18x10.5+34 which is kinda aggressive on an F but nothing to worry about. your all good.
#2488
I appreciate the advice. You should open a tip jar lol. Can't be afraid to rub a little.
#2489
and just in case any one chimes in on the F fitment. the fenders are a bit wider up front which will fit 18x9.5+22 just fine, fender liners might rub. rear has an extra 1/2" on each side of the car making it have 12mm less clearance than the standard ISx50's
#2490
Will this XXR-527 18x8.75 fit in 2008 is350? what tire size do I need to use?
is 265/45r18 too big for rear? I'm also thinking about 235/40r18 on front.....i dont know about offset yet. any recommendation?
http://www.xxrwheels.com/xxr_527.shtml
