Will those wheels fit? START HERE.
#2492
Will this XXR-527 18x8.75 fit in 2008 is350? what tire size do I need to use?
is 265/45r18 too big for rear? I'm also thinking about 235/40r18 on front.....i dont know about offset yet. any recommendation?
http://www.xxrwheels.com/xxr_527.shtml
235/40-18 up front is fine.
as far as offsets, given a square set-up (same widths for front/rear wheels) something in the mid 30's will allow you to run said suggested tire sizes.
#2494
I just order some Work wheels fronts 20x9 +30 (+25 w/ 5mm spacer required for BBK) with a 2" lip and rear 20x10 +25 with a 3.5" lip. Anybody know if this will be flush and only will require to cut or roll the fenders?!?! Need to buy tires still any recommendations on size? Going for a flush look not really a "Hella" flush style
#2495
http://www.vrwheels.com/ssr-vienna-polish-p-3964.html would these fit over IS calipers with spacers? If so what size spacers? Thx
#2496
my guess on tires would be 225/30-20 + 245/30-20.
the offsets are already aggressive enough that any spacers would lower the offsets even more. the lower the offset, the more fender work you'll need (not a matter of "if" but "how much").
#2498
it will be flush, and will require shaving/rolling the fenders.
is250 or the is350 calipers?
#2499
in the event those wheel specs don't clear the is350 calipers, you can always run spacers. i believe the maximum size spacer you can run up front is 10 mm.
235/40-18 should be fine.
camber is not adjustable from the factory, and to make camber adjustable there aren't many options - i can only think of one for the front and one for the rear.
please take the time to look and search through the 2is suspension subsection for more information regarding camber for the 2is.
#2504
Will it be ok for front with same 18x8.75? with 225? 235?
I'm worried because I think stock front is 8in wide..and I'm putting a lot wider size
