Will those wheels fit? START HERE.
Old 09-08-11, 07:02 PM
  #2566
syndrax
syndrax's Avatar
Front: 19X8.5 +30 - 226/35/19
Rear: 19X9.5 +35 - 265/30/19
Lowered on Tein S-Tech. Any modifications needed?
Old 09-08-11, 08:18 PM
  #2567
projectdna
projectdna's Avatar
Originally Posted by syndrax
Front: 19X8.5 +30 - 225/35/19
(fixed.)
based on your proposed wheel specs and current ride height, you should be fine without fender modifications.
Old 09-08-11, 11:59 PM
  #2568
lowis250
lowis250's Avatar
you will be fine. might rub a little when you hit a bump but thats all
Old 09-09-11, 04:09 AM
  #2569
kanklez
kanklez's Avatar
Anyone know how much less inner clearance that our is250 rwd can have before needing a spacer? found a set of rims, but there's gonna be 14mm less inner clearance front and back
Old 09-09-11, 02:50 PM
  #2570
Mv350
Mv350's Avatar
you will be ok with those
Old 09-09-11, 07:22 PM
  #2571
meefer
meefer's Avatar
19x8.5 +22 front with 215/35/19
19x10.5 +22 rear with 265/30/19 or 245/35/19
Lowered on F-sports, no fender mods save a little heat gun. I'm only really worried about the rear.
Old 09-10-11, 01:17 AM
  #2572
projectdna
projectdna's Avatar
you might be able to get away with no fender modifications given your ride height.
but given those wheel and tire specs, it's best that you give some consideration and plan for fender modifications.
on a slightly related note, i think i know what wheels you're looking at. my advice is, do it and don't look back.
Old 09-11-11, 11:14 PM
  #2573
2slixx
2slixx's Avatar
x114.3 Rim Width: 8.5 & 9.5
Hub Bore: 60.2 Rim Diameter: 19
Offset: +38 & +45
Will these rub on tien s techs or eibachs?
Im in a 06 250 rwd
Thanks in advance
Old 09-12-11, 07:00 AM
  #2574
Mv350
Mv350's Avatar
you shouldnt rub with 225/35 and 245/35
Old 09-12-11, 07:26 PM
  #2575
supadelish
supadelish's Avatar
I am looking at running a 19x8.5 - 19x9.5 setup on my 06 250 (rwd) offsets seem pretty conservative at +35 F - +40 R...
My question is what size tire would you recommend on these wheels- i was considering 235/35/19 and 275/30/19 -- the car will be dropped on H&R springs. I found a great deal on 225/35/19 and 245/35/19 and am also considering these as well...
hoping to avoid any rubbing issues and achieve an almost flush look while still maintaining the cars practicality - this is my daily, i already have one car with aggressive offsets, stretched tires and slammed on coils - i dont need two useless vehicles - LOL!!
Old 09-13-11, 12:29 PM
  #2576
AKhanis350
AKhanis350's Avatar
20x9 Front +15 Offset
20x10 Rear +20 Offset
5x114.3 Bolt Pattern
2.5" Front Lip, 4.5" Rear Lip
would they fit?
Old 09-14-11, 10:12 AM
  #2577
projectdna
projectdna's Avatar
235/35-19 + 265/35-19 (or 265/30-19) should be fine, though this is (imo) a conservative recommendation.
Old 09-14-11, 10:32 AM
  #2578
projectdna
projectdna's Avatar
would they fit?
depends on how much fender work you're willing to do.
Old 09-14-11, 10:42 AM
  #2579
hydralisk
hydralisk's Avatar
Speaking of fender work, Any precautions we should take before shaving the fenders? Is it fine with that seam?
Old 09-14-11, 10:53 AM
  #2580
Mv350
Mv350's Avatar
i shaved the rears all the way down. DO NOT SHAVE YOUR FRONTS, ROLL THEM FLAT.
Quick Reply: Will those wheels fit? START HERE.
