Will those wheels fit? START HERE.
#2581
Former Sponsor
Hey MV350:
First of all, great job / great support you are offering to the CL forums !
I got a wheel spec, wondering if you have seen it done on IS350 yet.
It's 20x9.5 +15 / 20x11.0 +5.
I have done 9.5 +15 in the front, but never done it in 20".
And also I have done 10.5 +15 in the rear, but never done it in 11.0 +5.
What do you think ? Going to attempt this on a new IS350.
![](http://www.ravspeconline.com/images/wheels/work/sc1/sc1-20-1219.jpg)
#2582
it will fit nicely with an 1" in the rear with a 265/30. you would also have to shave the rear bumper tab and move the bolt back about 3/4". As for the front im not aware of any changes with the fender/bumper tab. If it is the same your going to have to cut and relocate it further inward towards the headlight. the front will require ~12mm of pull to fit with a 225/35.
front camber~ -3* rear ~ -5* toe set at neutral. it will give you the most balance clearance around the entire fender, and save the tires.
hope it works out. i will have to say as a warning(i doubt youll have this problem) but if you are not good with a heat gun as not to burn your paint, and not the best with a roller i would not try to pull that much. i bet your guys know some one that is extremely good at this. the outcome of not knowing what your doing will fold the fenders and require paint. no matter what dont shave the front, just roll it all flat and pull to fit the wheels
it will fit. if there is a will there is a way. same way i fit 18x12+4 static on my 2gs.
#2584
I've got 19x9.5 +30, 19x10.5 +35 wheels. Looking for tires.. what should I be running? Lowered on H&R springs on IS350. What kind of fender work am I looking at? Will it need anything else? Thanks ahead of time!
#2586
i think i have found the wheels i want!!!!!!
question is how flush would these wheels be?
i have two options for front
19X8.5 5-114.3 30MGL
19X8.5 5-114.3 40MGL
and rear would be
19X9.5 5-114.3 25MGL
what do you guys think?
what tires should i run in front?
i plan on running 275-30-19 on rear, would that work?
and rear would be
#2588
and rear would be
and rear would be
i would run 19x8.5+30 with a 225/35 and the 19x9.5+25. just shave the fenders or roll them completely flat. the fronts roll flat. no need for a pull. just dont shave the fronts
#2591
and rear would be
and rear would be
19x8.5 +30 and 19x9.5 +25.
roll the fenders, but no pull. depending on how low your ride height will be, you'll need to relocate/remove fender/bumper bolts and tabs - all four corners.
225/35-19 + 245/35-19 should clear the fenders.
#2592
+1 on what Mv350 suggested. so to repeat...
#2594
he can try 255/35-19, but that'll need fender mods, definitely.
btw, i thought you knew.
